Understanding Voltage: Common Questions and Answers in Basic Physics
  • Thread starter Thread starter Kyoma
    Voltage
Voltage is defined as the potential difference between two points, which is crucial for current to flow. A bird perched on a live wire with both feet does not get electrocuted because there is no potential difference between its feet, while one foot on the ground creates a significant difference, allowing current to flow through the bird. In household wiring, the live wire carries voltage, while the neutral wire is at ground potential, resulting in no voltage reading. The brightness of a light bulb is determined by both voltage and current, as power is the product of these two factors. Understanding these concepts requires further study of electricity and its principles.
Kyoma
I think I have a wrong definition of the word 'voltage'. For example, a bird perching on a live wire with its 2 legs will not be electrocuted, but a bird perching with one of its legs on the ground and another on the wire will be electrocuted. Why? Wouldn't the current pass through the bird regardless of the bird's feets' positions? Why wouldn't it die when it has two of its feets on the wire?
Furthermore, in practical electricity, there are the live and neutral wires. The live wire records a voltage reading but the neutral doesn't. Why?
Lastly, voltage or current or both of them would affect the brightness of a light bulb?
Thanks. I'm relatively new to physics, so I need some simple answers. :P
To be electrocuted, a large number of charges in the bird's body have to move (electrical current). The charges will move only if they are pushed. In order to be pushed, a potential difference is required. If there is no potential difference between the contact points (feet) there will be no electric field (electric force) created in the bird's body to push the electrons.
If both feet are on the wire, the feet are at the same potential. There is no potential difference if both feet are on the wire (eg. +15000V to +150000V) so no current flows. If one foot is on the wire (eg. +15000V) and the other is at ground (0V), the potential difference is huge (+150000V) and current flows through bird.
In typical household AC there are 4 wires, a red, black, white and copper (ground) wire. The copper wire is connected to ground so there is no potential difference between it and ground. The others are connected to a voltage source. There is a potential difference between those wires and from the wires to the ground.
The power in a light bulb is the product of voltage x current. Since voltage is supplied from a constant voltage source, the current is determined by the resistance of the light bulb according to Ohm's law: V = IR; I = V/R
AM
But isn't the current still flowing in the wire? Aren't the electrons still being pushed in the wire?
I know. But, why wouldn't the live wire have a zero voltage while the neutral voltage have a recorded voltage? Why does it have to be the other way?
Yes. There is very small potential difference from one end of a transmission wire to the other. That is because copper is a very good conductor. So there is almost no potential difference between the bird's two feet. A significant potential difference is needed in order to drive electrons through a bird. You will understand this better when you study electricity in greater depth.
Voltage is potential DIFFERENCE. The convention is to give the earth, which is essentially electrically neutral (no net charge) a potential of 0. All other voltages are measured relative to that.
I would suggest you read a good book on electricity and see if you can answer some of these questions yourself. That is a good way to learn.
AM
Just to add a thought: Kyoma, have you tried using a voltmeter? In order to measure a voltage you have two leads. That's important, because as Andrew Mason discusses, you need to compare the potential at one point with the potential at another.
It may be shown from the equations of electromagnetism, by James Clerk Maxwell in the 1860’s, that the speed of light in the vacuum of free space is related to electric permittivity (ϵ) and magnetic permeability (μ) by the equation: c=1/√( μ ϵ ) . This value is a constant for the vacuum of free space and is independent of the motion of the observer. It was this fact, in part, that led Albert Einstein to Special Relativity.
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
