MHB How do you simplify sqrt{12x^7}?
  • Thread starter Thread starter mathdad
    Radical Simplify
The expression sqrt{12x^7} simplifies to 2|x^3|sqrt{3x}, accounting for the absolute value of x due to the square root. The breakdown involves recognizing that sqrt{x^6} equals |x^3|, which is important for values of x that are negative. While some resources, like Wolfram, present the answer as 2sqrt{3}•sqrt{x^7}, the inclusion of absolute values is a more rigorous approach. The discussion highlights a common educational oversight regarding the treatment of square roots and absolute values in algebra. Overall, the correct simplification emphasizes the necessity of absolute values in the context of square roots.
mathdad
Simplify sqrt{12x^7}
Solution:
sqrt{4•3•x^6•x}
2x^3(sqrt{3x})
Is this correct?
Note 1:
According to wolfram, the answer is 2sqrt{3}•sqrt{x^7}
Note 2:
The term x^3 in my answer comes from the breakdown of sqrt{x^7} as sqrt{x^6•x}. Isn't sqrt{x^6} the same as x^3?
Mathematics news on Phys.org
Your working assumes $0\le x$...it would be more proper to say:
$$\sqrt{12x^7}=2\left|x^3\right|\sqrt{3x}$$
Because:
$$|x|\equiv\sqrt{x^2}$$
Because:
Back in high school over 30 years ago, my teachers never taught to include the absolute value to a square root problem. For me sqrt{x^2} = x not the |x| but of course, you are right.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
