MATLAB Simplify Matlab for/if statements further
  • Thread starter Thread starter bugatti79
    Matlab Simplify
The discussion revolves around simplifying a loop in MATLAB code that populates a 3x3 matrix `k` using the `subs` function with a 3x1 vector `SE_ans`. The original code redundantly calls `subs` multiple times with the same arguments for each row of `k`. A suggestion is made to streamline the code by utilizing a loop for the first index of `k` and storing the parameters in arrays before the loop. This approach reduces redundancy and enhances code efficiency. The original poster confirms that they successfully implemented these suggestions, resulting in a more concise and functional code structure.
bugatti79
Hi Folks,
This loop code is working fine but I would like to simplify it further. Can anyone help?
Basically, i need syntax to automate the numbers highlighted in bold.
k is a 3*3 matrix, SE_ans is a 3*1 vector, A is a 3*3 identify matrix. The rests are just constants.
Code:
  for i=1:size(k,1)
k([B]1[/B],i)=subs(SE_ans([B]1[/B],:),[theta_1, theta_2, theta_3, k_t1,k_t2,k_t3],[A(i,[B]1[/B]), A(i,[B]2[/B]), A(i,[B]3[/B]),1,2,3])
k([B]2[/B],i)=subs(SE_ans([B]2[/B],:),[theta_1, theta_2, theta_3, k_t1,k_t2,k_t3],[A(i,[B]1[/B]), A(i,[B]2[/B]), A(i,[B]3[/B]),1,2,3])
k([B]3[/B],i)=subs(SE_ans([B]3[/B],:),[theta_1, theta_2, theta_3, k_t1,k_t2,k_t3],[A(i,[B]1[/B]), A(i,[B]2[/B]), A(i,[B]3[/B]),1,2,3])
  end
Thanks
The [ code ] tags are preventing the bold tags from being rendered correctly. Normally it's a good thing to put your code inside code tags, but not in this case.
for i=1:size(k,1)
k(1,i)=subs(SE_ans(1,:),[theta_1, theta_2, theta_3, k_t1,k_t2,k_t3],[A(i,1), A(i,2), A(i,3),1,2,3])
k(2,i)=subs(SE_ans(2,:),[theta_1, theta_2, theta_3, k_t1,k_t2,k_t3],[A(i,1), A(i,2), A(i,3),1,2,3])
k(3,i)=subs(SE_ans(3,:),[theta_1, theta_2, theta_3, k_t1,k_t2,k_t3],[A(i,1), A(i,2), A(i,3),1,2,3])
end
Why do you call subs 3 times with the same arguments? Also, why not add a loop for the first index of k? I would also set
Code:
tk = [theta_1, theta_2, theta_3, k_t1,k_t2,k_t3];
AA = [A(i,1), A(i,2), A(i,3),1,2,3];
before the loop, and use that inside the loop.
Hi DrClaude,
yes, you are right. I reduced it down to one line and use a double if loop. Works fine now
Thanks
