MHB How Can I Simplify This Complex Mathematical Expression?
The discussion revolves around simplifying a complex mathematical expression involving variables z and w, specifically with w set to 2. A participant requests help in simplifying the expression and calculating its value. Another user clarifies the expression and successfully simplifies it to show that the final result is w³, which equals 8 when w is 2. The conversation highlights the importance of understanding multiple methods for solving mathematical problems. The exchange concludes with a light-hearted comment about the user's ability to solve the problem despite initial confusion.
headbang
Hello,
I am having difficulty solving my math problems.
Simplify the Expression and show how.. And kalkulate
z²+w(2wz)²-(w+4z²-1)w³-(z+w²)(x-w²)
And w=2
I know we have many ways doing it, an the more ways i can study, the bether i can understand this..
Mathematics news on Phys.org
headbang said:
Hello,
And w=2
Do you maybe mean:
$z^2+w(2wz)^2-(w+4z^2-1)w^3-(z+w^2)($z$-w^2)$
($z$ instead of $x$) ?? (Wondering)
If so, it is as followed:
$$z^2+w(2wz)^2-(w+4z^2-1)w^3-(z+w^2)(z-w^2) \\ =z^2+w 4 w^2 z^2-ww^3-4z^2w^3+w^3-(z^2-zw^2+zw^2-w^4) \\ =z^2+4 w^3 z^2-w^4-4z^2w^3+w^3-(z^2-w^4) \\ =z^2-w^4+w^3-z^2+w^4=w^3$$
For $w=2$ we have
$$2^3=8$$
You are so good.. You solved it even if i can't read and Write the right Expression... :)
I suspect that MHB is conducting secret genetic experimentation on some members to promote psychic abilities.
-Dan
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
