How can exponents be simplified?
The discussion focuses on simplifying the expression [-6(-4)^(n-1)] - 9 + [8(-4)^(n-2)] + 12 to reach the result of 2(-4)^n + 3. Participants clarify that the simplification involves factoring out common terms and applying exponent rules, specifically X^(a+b) = (X^a)(X^b). The expression can be rearranged by recognizing that terms can be combined based on their exponents. Understanding the relationship between exponents and factoring is crucial for this simplification process. The final result confirms that the correct simplification leads to 2(-4)^n + 3.
Thunderer
Well here is the beginning of it:
This is suppose to simplify to 2(-4)^2 + 3.
But I have no idea how that 2(-4)^2 was obtained. Could anybody explain how that would work?
i'm going to assume you meant 2(-4)^n not ^2, because otherwise you'd've simplified further, and besides, ^n is the correct answer. do you know how exponentials work and how to factor? that's all they did, and then simplified.
use these rules:
and by that:
X^(a+b) + X^(a+c) = X^a(X^b + X^c)
It also helps to know that 4= 2^2!
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
