Simplifying correlation coefficient
Dustinsfl
The linear prediction of one random variable based on the outcome of another becomes more difficult if noise is present. We model noise as the addition of an uncorrelated random variable. Specifically, assume that we wish to predict ##X## based on observing ##X + N##, where ##N## represents the noise. If ##X## and ##N## are both zero mean random variables that are uncorrelated with each other, determine the correlation coefficient between ##W = X## and ##Z = X + N##. How does it depend on the power in ##X##, which is defined as ##E_X[X^2]##, and the power in ##N##, also defined as ##E_N[N^2]##?
The correlation coefficient is define as
\rho_{W, Z} = \frac{cov(W, Z)}{\sqrt{var(W)var(Z)}}.
Let's note some standard identities which may be useful.
\begin{align*}
cov(X + Y, X) &= cov(X, X) + cov(Y, X)\\
cov(X, X) &= var(X)\\
var(X + Y) &= var(X) + var(Y) + 2cov(X, Y)
\end{align*}
Since ##X## and ##N## are uncorrelated, ##cov(X, N) = 0##.
I have reduced the coefficient down to
\begin{align*}
\rho_{W, Z} &= \frac{cov(W, Z)}{\sqrt{var(W)var(Z)}}\\
&= \frac{\sqrt{var(X)}}{\sqrt{var(X) + var(N)}}\\
&= \sqrt{\frac{E[X^2] - E^2[X]}
{E[X^2] - E^2[X] + E[N^2] - E^2[N]}}\\
&= \frac{1}{\sqrt{1 + \frac{E[N^2] - E^2[N]}
{E[X^2] - E^2[X]}}}
\end{align*}
but the answer can be reduced further to
\sqrt{\frac{\eta}{\eta + 1}}
where ##\eta = \frac{E[X^2]}{E[N^2]}##.
I don't see how I can get to this expression.
You are given E[X] and E[N].
Likes Dustinsfl
From this part (emphasis added) - "If X and N are both zero mean random variables that are uncorrelated with each other.."
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
