Simplifying Expression using Logarithms
34 replies · 7K views
jahaddow
Simplify the attached expression using any relevant logarithmic rules
I haven't really done much with logarithms, so i didnt know where to start?
Given problem can be written as
log(2)4 + log(16)1/4 + log(1/4)2 - log(7/4)
Now use laws of logarithm to simplify.
jahaddow said:
the problem is I don't know how to do that?
log(a) + log(b) = log(ab)
log(a) - log(b) = log(a/b)
Then you should start by learning the "relevant logarithmic rules"!
[itex]log(ab)= log(a)+ log(b)[/itex]
[itex]log(a/b)= log(a)- lob(b)[/itex]
[itex]log(a^b)= b log(a)[/itex]
No, you need to solve it yourself; you received sufficient help in the previous posts. Follow that advice.
Post what you have tried so far pertaining to the advice, or post and ask a question regarding the advice. If I asked you to simplify log(a) + log(b), how would you do it?
Yes, so look at the 3 logarithm rules provided by HallsofIvy and apply them to your problem.
ok so I'm up to log(2^2) + log(16^1/4) + log(1/4^2) - log(7/4)
Instead of log(22) it should be something else. Now, continue until you get an expression with only one log.
yes ok it would be log(2^4), but then I really am stuck on what to do next!
jahaddow said:
well that would be log(ab)
Follow your own advice. :wink:
jahaddow said:
I don't know how to!
OK.
What is 24, 161/4 and 42?
Substitute these values in my post #2 and simplify by using the relevant equation given by us.
Ok, now I have one which is attached.
I have managed to get to this
logx4/logx1/3
What do I do from here?
jahaddow said:
Or would it be 12logx? I don't know.
Your answer for the first problem is correct. But write it as a single number, not in the form of a fraction.
In the second problem from where did you get log(x) along with 12?
The second problem, I worked out to be just 12 now. But the first problem, 2/1.75 equals a long decimal, so wouldn't I just leave it as a fraction?
In that case you can write it as 8/7
just one more question, how do I simplify this and express with positive indices.
(18x^3 X 2x^-4)/(4x^-5 X 6x)
[tex]\frac{36x^3}{x^4}\times\frac{24x}{x^5}[/tex]
Now simplify.
could someone plese show a bit more detail with the second problem, where did 12 come from.
= [tex]\frac{4\times3\log{x}}{\log{x}}[/tex]
Now siplify.
I missed the step before that. wheres the 3 come from?
Sorry I am really bad at this.
[tex]\frac{1}{\frac{1}{3}\log{x}} = \frac{3}{\log{x}}[/tex]
