Simulation of load-unload test in Abaqus
  • Thread starter Thread starter Faezeh
    Abaqus Simulation
The forum discussion focuses on simulating a load-unload test in Abaqus, specifically addressing issues with negative forces and stresses in the model. The user encountered unexpected negative values in the force-displacement and stress-strain curves, which should theoretically be positive. A solution was provided, recommending an increase in the resolution of the loading amplitude by adjusting the increment from 0.001 to 0.0001. Additionally, starting with a single hex element and consulting the Abaqus verification guide were suggested as effective troubleshooting steps.
  • Familiarity with Abaqus software and its UMAT implementation
  • Understanding of tensile testing and stress-strain relationships
  • Knowledge of boundary conditions and amplitude definitions in finite element analysis
  • Experience with numerical simulations and model validation techniques
  • Investigate Abaqus amplitude settings and their impact on simulation results
  • Learn about the Abaqus verification guide for best practices in modeling
  • Explore techniques for refining mesh resolution in finite element models
  • Research common pitfalls in cyclic loading simulations and how to avoid them
This discussion is beneficial for mechanical engineers, finite element analysts, and researchers involved in material testing and simulation using Abaqus, particularly those facing challenges in accurately modeling tensile tests.
Faezeh
Hello,
I am trying to simulate the load-unload test in Abaqus under the following loading schedule using my UMAT (which has already been validated).
As you see, the load-unload test is pure tensile with positive displacements; however as I modelled it in Abaqus the force-displacement curve as well as the stress-strain curves give me some negative forces (stresses), while theoretically all the stresses and strains should be positive. Here is the numerical load-displacement curve which is obtained from Abaqus:
This is the experimental result (Stress-strain):
As you see there shouldn't be any negative forces (stresses) in the model. I don't know what is the problem with the model. it should be noted that I tried the model which is in this YouTube video ()
Hi,
I have encountered this issue in my cyclic loading tensile test simulation but only my stresses were negative. This usually occurs when you have defined a displacement boundary condition using amplitude to replicate the loading. Since we implement a defined displacement at a defined time step/increment, the stress tends to "overshoot" into the negative region to compensate for this definition as well as calculations done for the material by Abaqus.
I fixed it by increasing the resolution of the amplitude of loading i.e., more points in the amplitude (increasing increment from 0.001 to 0.0001 for example)
Also, I am unable to see your Abaqus result.
Hope this helps. Good luck.
