Simultaneous Equations (How to test for redundancy)
The discussion focuses on solving three simultaneous equations to express F without involving y²₀ or y²₁. The user is concerned about redundancy when solving equations 2 and 3 separately to eliminate y² terms. It is clarified that substituting y₀ from equation 2 into equation 3 to solve for y₁, and vice versa, is a standard method that does not create redundancy. The resulting expressions for y₀ and y₁ can be substituted back into equation 1 to find F in terms of x₀ and x₁. Ultimately, the approach is valid and can yield unique numerical values for the variables involved.
miniradman
I have three equations:
## F = ρw(x_0 y^2_0 - x_1 y^2_1) + \frac{1}{2} γ w (x^2_0 - x^2_1)## ----- 1
##y_0 = y_1 \frac{x_1}{x_0}## ----- 2
##\frac{y^2_0}{2} + gx_0 = \frac{y^2_1}{2} + gx_1## ------ 3
N/A
My goal is to have ##F## expressed without either ##y^2_0## or ##y^2_1## involved in the equation. My problem is that equations 2 and 3 involve both ##y^2_0## and ##y^2_1## so when it comes to eliminate one of them in equation 1, I re-introduce the other in the equation (and vice-versa). My question is whether or not it's legal to simultaneously solve equations 2 and 3 in two different ways (have ##y^2_0## and ##y^2_1## as subjects), then substitute each equation back in equation 1? Does solving the same simultaneous equation twice to obtain two equations with different subjects make them redundant?
N/A
If you substitute ##y_0## from eq. (2) into eq. (3), that will give you an equation involving ##x_0, x_1, y_1## alone, which you can then solve for ##y_1##, That will give you an expression for ##y_1## in terms of ##x_0,x_1## only; substituting that into eq. (2) will give you ##y_0## in terms of ##x_0,x_1##. Messy, but do-able.
Hi Ray, thanks for the response.
I understand I can get equation 2 in terms of ##x_0 , x_1##, however my ultimate goal is to get ##F## in terms of ##x_0, x_1## . I'm worried that using the same equation twice will create redundancy. Would I be able to use the resulting ##y_0## and ##y_1## in equation 1 with no hassle?
There is no redundancy in the method I suggested (which, by the way, is 100% standard). Eq (2) gives you ##y_0## in terms of ##x_0,x_1,y_1##. Putting that into eq. (3) allows you to get ##y_1## in terms of ##x_0,x_1##: ##y_1 = Y_1(x_0,x_1)## for some explicit function ##Y_1##. If you have numerical values for the inputs ##g,w,\rho, \gamma##, I can give you arbitrary numerical values for ##x_0,x_1##, and you can use your function ##Y_1## to get a unique, well-defined numerical value for ##y_1##. (Actually, there are two unique values with opposite signs, depending on which square root of ##y_1^2## you choose.) You can then take your now-known numerical values of ##x_0, x_1,y_1## and use eq. (2) to get the numerical value for ##y_0##. Now you can put all those value into your ##F##. Except for the "sign" issue, where is the redundancy in any of that? If you have some reason for choosing, say, the positive square root for ##y_1## then all uncertainty and ambiguity disappears.
