What is the solution for Ry in Sin 0=Ry/Rx when given values for Rx and theta?
  • Thread starter Thread starter niknak98
    Sin
The discussion revolves around solving the equation Sin(0) = Ry/Rx, where confusion arises regarding whether "0" should actually be "theta." It is clarified that if Sin(0) is indeed used, then Ry must be zero, and Rx can be any non-zero real number. The correct interpretation is likely Sin(theta) = Ry/Rx, which allows for proper solutions for Ry, Rx, and theta through algebraic manipulation and inverse functions. The participants emphasize the importance of accurately representing theta in the equation. Ultimately, the teacher confirmed the correction, validating the interpretation of the variable.
niknak98
Teacher assigned this on first day due tomorrow and i have no clue on some like this one:
Sin 0=Ry/Rx a.) solve for Ry
b.) solve for Rx
c.) solve for 0
Is there anymore information you can provide? Is that actually Sin(0)? Did you attempt to solve it on your own? Have you tried the inverse function?
Anyway, if it really is 0 then it should be obvious. Ry would have to be zero. Rx is then any real which is not equal to zero. Rewriting the equation as arcsin(Ry/Rx) = 0 will demonstrate this as well. I'm saying this because part of me doesn't believe that is really supposed to be sin(0), instead it's probably theta.
I can make absolutely no sense out of "solve for 0"! That would be like saying "solve for 2".
I strongly suspect that was supposed to be sin(\theta)= R_y/R_x and your teacher (or you!) missed the horizontal line on the \theta.
To "solve for y", multiply both sides by R_x. To "solve for x" one method is to first invert both sides, getting 1/sin(\theta)= R_x/R_y and then multiply both sides by R_y. To "solve for \theta" take the inverse sin (arcos or sin^{-1}) of both sides.
Thanks this really helped and he did correct it that the 0 was theta
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
