PhysicsStuff said:
Is there a single equation that can model both spatial and temporal metric contraction simultaneously? And also what's that equation that can model the actual degree of curvature n space-time that uses trig functions and how do you use that in combination with the two previously mentioned equations to model the dimensional metric contraction caused by curvature?
There are 10 simultaneous partial differential equations involving the 10 metric coefficients g_ij, and their first and second partial derviatves with respect to time and space. This is the "left side" of Einstein's equation,
G_ij = 8 pi T_ij
The capital G_ij is not the same as the lower case g_ij G_ij is the "Einstein tensor". The equation above becomes a partial differential tensor equation when one expands each of the G_ij in some basis in terms of the g_ij and their first and second partial derivatives.
In a vacuum, the right hand side of the equation, i.e. all the T_ij are zero. More generally the T_ij represent the matter distribution.
By some counts there would be 16 g_ij, as i and j can each take on the values 0,1,2,3. But because of the symmetry condition g_ij = g_ji, there are only 10 "different" metric coefficients.
While there are 10 equations, they're not independent, there is one "constraint equation", so there are actually 9 indepenent equations and 9 variables. Similar remarks can be made about the right hand side, T_ij.
The 10 g_ij are the metric coefficients - I'm not sure why you refer to them as "metric contractions", that's not a standard term. Possibly you are thinking of something else when you ask about "metric contraction" (perhaps related to time dilation?), but it's not clear to me what you might be thinking of. I'm concerned that you may have intended to asked a different question than the one I answered due to semantic issues.
The metric coefficients are a quadratic form that gives the square of the "distance" (more precisely the Lorentz interval) between two points.
Thus, if you have (t,x,y,z) as coordinates, there will be some expression for the square of the lorentz interval, ds^2
ds^2 = g_00 dt^2 + 2 g_01 dt dx + 2 g_02 dt dy + 2 g_03 dt dz + g_11 dx^2 + 2 g_12 dx dy + 2 g_13 dx dz + g_22 dy^2 + 2 g_23 dy dz + g_33 dz^2
the 10 numbers (g_00, g_01, g_02, g_03, g_11, g_12, g_13, g_22, g_23, g_33) are the metric coefficients.
ds^2 could be the square of a distance, or the square of a proper time, depending on your sign conventions.
