Singularity theorms and perturbation from exact symmetry
julian
The singularity theorems apply to situations away from exact symmetry ... away from Schwarzschild solution or Friedmann solutions for example. There are a number of accounts of the singularity theorems but none addressing the problem of proving a 'trapped set' still persists after slight perturbation away from exact symmetry (except maybe Hayking and Ellis? Difficult book to read.).
Should I read more about the Cauchy problem for GR and on how solutions depend continuously on the initial conditions to find out if trapped surfaces still exist away from exact symmetry?
Where's the best place to find out about this stuff?
In martin Bojowald's book's ,page 201 he says "even if one perturbs around the Schwarzschild solution, specific values of expansions of null congruemces may change, but for sufficiently small perturbations they will remain negative if they are negative for the unpereturbed solution"
Does anyone know a place to look to find the proof of this?
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
