Sinking a cylinder with varying hole sizes
97 replies · 15K views
on Phys.org
haruspex said:
Right.
But A and h are constants, so can you rewrite that in the form dy/dt=...?
##\frac{dy}{dt}=\frac{va}{A-h}##?
haruspex said:
The next step is the Bernoulli equation. Need to be careful, though. The v I defined is relative to the cylinder, and the cylinder is moving. Bernoulli will tell you the gained velocity in the lab frame.
So if ##u## is the negative, downwards velocity of the cylinder [at the hole = above the hole]
##\frac{1}{2}\rho (v+u)^2+\rho gz_{1}+P_{1}=\frac{1}{2}\rho (\frac{a(v+u)}{A})^2+\rho gz_{2}+P_{2}##?
No, you've made some mistake in the algebra. Try again. A-h makes no sense, you cannot subtract a distance from an area.
Not sure which is 1 and which is 2, but the water is stationary below the hole.
As already noted, z1=z2, so you can cancel those.
What expressions do you have for P1 and P2?
##\frac{d(Ay)−d(Ah)}{dt}=va ##
##\frac{Ad(y)−Ah}{dt}=va ##
##\frac{d(y)−h}{dt}=\frac{va}{A} ##
##\frac{d(y)}{dt}=\frac{va}{A}+h##
Is this correct?
I see.
Below the hole = Above the hole
##\frac{1}{2}\rho (0) + \rho gz_{1}+P_{1}=\frac{1}{2}\rho (v+u) + \rho gz_{2}+P_{2}##
Since ##z_{1}=z_{2}##
##P_{1}=\frac{1}{2}\rho (v+u) +P_{2}##
I rewrite pressure in terms of the depth from the surface of water?
##P_{1} = \rho gy## and ##P_{2} = \rho gh## so
##\rho gy=\frac{1}{2}\rho (v+u)+\rho gh##
##gy=\frac{1}{2} (v+u)+ gh##
Is this correct?
No. A and h are constants, so what is the change in Ah, d(Ah), in time dt?
You would have seen something is wrong if you had checked dimensional consistency.
Yes, except that you have omitted the power of 2 on the velocity term. Again, dimensionally inconsistent.
Oh...
##\frac{d(Ay)-d(Ah)}{dt}=va##
##\frac{d(Ay)}{dt}-\frac{d(Ah)}{dt}=va##
##\frac{dy}{dt}=\frac{va}{A}##
##gy=\frac{1}{2}(v+u)^2+gh##
##2g(y-h)=(v+u)^2##
##\sqrt{2g(y-h)}=v+u##
So the downwards velocity of the cylinder is
##u=\sqrt{2g(y-h)}-v##?
At this point do I return to the force equations? I'm still not sure how this all connects back to it.
Sorry, I forgot to reply...
Your post #37 is correct, but note the dy/dt and u are the same thing, so you can combine those equations to eliminate u.
##\frac{va}{A}=\sqrt{2g(y-h)}-v##
##a=\frac{A(\sqrt{2g(y-h)}-v)}{v}##
So now I need to make this equation in terms of ##t## and ##a##, right?
Since
##F_{buoyancy}=\rho gV## and ##V=Ah##
## F_{buoyancy}=\rho gAh ##
Because ##frac_{dy}{dt}=frac_{va}{A}##
##t=\int \frac{va}{A}dy##
Since ##v##, ##a##, ##A## are constants
##t= \frac{vay}{A}##, so ##A=\frac{vay}{t}##
##V=\frac{vay}{t}h##
##F_{weight}=F_{buoyancy} + F_{drag}##
##(m_{water}+m_{cylinder})g=\rho g \frac{vay}{t}h -bv##
##(\rho V+m_{cylinder})g=\rho g \frac{vay}{t}h -bv##I suppose I do some rearranging magic for the ##v## of the drag force using the equation I got in #40?
haruspex said:
I could see something was going wrong. Just traced it to this:
That is not correct. What is the water depth just above the hole?
Is it the ##P_{2}=\rho gy## because they're at the same height (##z_{1}=z_{2}##)? But that would mean ##P_{1}=P_{2}##?
haruspex said:
No. Look at your diagram in post #24. What is the depth of water inside the cylinder?
Right, so ##y-h##; ##P_{2}=\rho g(y-h)##
haruspex said:
Yes.
So I get
##\rho gy=\frac{1}{2}ρ(v+u)+ρg(y-h)##, and rearrange for ##u##?
So I get
You have forgotten to square the velocity term again.
After fixing that, rearrange for v and eliminate v using the u=dy/dt=va/A equation you had in post #37.
##gy=\frac{1}{2}(v+u)^2+g(y-h)##
##2gy-2g(y-h)=(v+u)^2##
##2gh=(v+u)^2##
##\sqrt{2gh}=v+u##
##v=\sqrt{2gh}-u##
##u=\frac{va}{A}##, ##v=\frac{uA}{a}##
##\frac{uA}{a}=\sqrt{2gh}-u##
##uA=a\sqrt{2gh}-au##
##u(A+a)=a\sqrt{2gh}##
##u=\frac{a\sqrt{2gh}}{(A+a)}##
##2gh=(v+u)^2##
##\sqrt{2gh}=v+u##
##v=\sqrt{2gh}-u##
Yes!
Last step is to find the time taken. You need to think a bit here about the initial and final values of y. Start by imagining what would happen if there were no hole.
haruspex said:
Yes!
##y## would be 0 if there were no hole, no matter the time because it would be on the surface of the water. But also ##y## varies from 0 to the height of the cylinder if there is a hole.
Since ##\frac{dy}{dt}=\frac{va}{A}## couldn't I integrate this with ##t=\int{\frac{va}{A}dy}##?
haruspex said:
No, the cylinder has weight. Apply Archimedes.
I'm really not sure...##F_{b}## would be 0 to ##\rho g y##.
haruspex said:
If you put a dish on a bucket of water does it sit on the surface, not immersed at all?
It would displace the volume of ##Ay## on the surface and the volume equal to that of the cylinder when underwater.
y is a variable.
Let the mass of the empty cylinder be M. Seal up the hole and place the cylinder on the surface. How far will it sink into the water? Use Archimedes.
haruspex said:
y is a variable.
Well it displaces it's own weight so the buoyancy is equal to ##\rho g \frac{Mg}{\rho}##
haruspex said:
Too many g's. The buoyant force will be Mg. So what volume is displaced?
##\frac{M}{\rho}##?
##\frac{M}{\rho}##?
Right.
So now let's think about what will happen when a cylinder with a small hole is placed on the water and released. The flow through the hole will be relatively slow, so the initial behaviour will be much the same as with no hole, namely, that it will immediately sink until it displaces volume ##\frac{M}{\rho}##.
What value of y will result?
