Sir Lancelot Equilibrium Bridge Problem
The discussion revolves around a physics problem involving Sir Lancelot on a drawbridge with a critical tension limit. The bridge's mass and the combined mass of Lancelot and his horse are provided, and the goal is to determine the distance from the castle end where the center of gravity will be when the cable breaks. Participants highlight issues with calculating torques and suggest correcting the sign in the torque equation to ensure both terms are aligned in direction. The tension value used in the calculations is also questioned, indicating a need for reevaluation. Ultimately, accurate torque analysis is essential for solving the problem correctly.
Dillio
Sir Lancelot rides slowly out of the castle at Camelot and onto the 12.0-m-long drawbridge that passes over the moat. Unbeknownst to him, his enemies have partially severed the vertical cable holding up the front end of the bridge so that it will break under a tension of 5.80 * 10^3 N. The bridge has mass 200 kg and its center of gravity is at its center. Lancelot, his lance, his armor, and his horse together have a combined mass of 600 kg.
If so, how far from the castle end of the bridge will the center of gravity of the horse plus rider be when the cable breaks?
I hate to say this, but I have no idea where to start. I tried to solve for the distance by:
Torques = (600)(9.8)(x) - (200)(9.8)(6) = (5.8 * 10^3)(12)
It says my tension value is wrong for what is holding the bridge up. The tension is located 12m from the opening of the castle, but apparently I need to solve for my tension in another way.
Any suggestions?
Torques = (600)(9.8)(x) - (200)(9.8)(6) = (5.88 * 10^3)(12)
Why the negative sign between the first two terms? (Those torques are in the same direction--they should have the same sign.) Correct that error and you should be fine.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
