Sliding conductor on a metal rail, with perpendicular B-field
When a metallic conductor rod is pushed in a perpendicular magnetic field, it experiences induced current due to a change in magnetic flux. The induced current generates a force that opposes the rod's motion, leading to a deceleration effect. Initially, there was confusion about the direction of the induced current and the resulting force on the rod, but it was clarified that the induced current is clockwise, resulting in a force that acts to the right. This force ultimately slows the rod down, contradicting the idea that it would continue moving indefinitely. The discussion emphasizes the principles of electromagnetic induction and the opposing nature of induced forces.
serverxeon
In the following diagram, the brown metallic conductor rod is given a slight push to the left.
The black lines are all conducting wires, with the entire setup placed in a perpendicular B-field. Ignore friction.
What will happen?
1) The rod slowly come to a stop?
2) The rod continues to move at constant speed?
3) The rod comes to a stop and reverses direction?
[PLAIN]http://img52.imageshack.us/img52/9687/magqj.png
1) I think this should be the answer, as kinetic energy has to be converted to electrical current (heating of the wires). The motion has got to die down.
However, I cannot identify the retardation force that acts on the rod which is necessary for the motion to stop.
2) I don't think it's going to move forever as argued above.
3) I seriously doubt this man. Intuition, somehow.
What will happen?
As the conductor moves to the left, the area of the loop reduces. That means the amount of flux threading the loop reduces. That reduction in flux means a current is induced in the loop. Once that current is flowing through the moving wire, a force is induced on that wire [F = B.I.l ] that is the force that stops the wire.
Hmm, but,
the direction of the induced current in this case is anti-clockwise.
Therefore, the direction of the current in the rod, is upwards.
Wont the force on the rod be to the left?! that's not retardation?
serverxeon said:
Hmm, but,
Induced Forces ALWAYS oppose change so one of those direction reckonings is backwards. See if you can work out which one.
oh! sorry a slipped on my part.
so it's clockwise induced current. B-force is therefore on the right.
I see. thanks.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
