Sliding friction, position/velocity as a function of time?
Calculating the position and velocity of a particle with non-zero velocity and acceleration, while accounting for sliding friction, is indeed possible. The friction force, which opposes movement, can complicate the equations of motion but can be integrated into a continuous model. The challenge lies in defining the function f(dt) that represents the effects of friction over time, as it may vary based on the particle's changing velocity and direction. Kinetic friction is inherently piecewise due to its dependence on the direction of movement and the forces acting on the particle. A continuous physics simulator can incorporate these dynamics by carefully modeling the frictional force in relation to the applied forces.
mcevans
If this question is completely stupid, forgive me, I'm a few years out of university and math and physics are quickly leaving my brain... :)
Say a particle has a non zero velocity in one direction and a non zero acceleration in the opposite direction. If you also account for some sliding friction force opposing this movement, is it still possible to calculate its position and velocity as functions of time?
I've been googling around for a while and can't seem to come up with what I want. I'm trying to write a little (extremely simplified) continuous physics simulator, and after some timestep dt I need to be able to say "new_x_position = velocity * dt + f(dt)" where f is some mystery function- right now the only things I can come up with are piecewise functions.
edit: I should clarify- the source of my confusion is that sliding friction can never exceed whatever applied force is causing the particle's acceleration, and must always oppose movement, even if the particle's direction changes during that timestep
I guess this question could be summarised as, "Is kinetic friction inherently piecewise?"
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
