Slow clocks on moving body is an illusion?
  • Thread starter Thread starter jakesee
    Body Clocks
jakesee
Hi,
I chanced upon https://www.physicsforums.com/showthread.php?t=321935 and read Doc AI's reply basically saying: if 2 bodies moving near speed of light relative to each other, the clocks on the other body will appear slower on either body.
And I think this should theoretically mean the slowness is only an effect of observation (as an inability to observe to great accuracaries due to some unknown limitations of observation devices such as the eye etc.) and not in reality happening. Is this correct or wrong?
Or has it been experimentally shown that a moving body really has all processes slowed down. e.g. a slowed chemical reaction? I really don't think this is the case because if Doc AI is correct, the people carrying out the experiment are the ones moving with respect to the experiement itself!
Or even weirder, is to say that sending one single object to the past/future is relativitiscally equivalent to sending the rest of the universe to the future/past. Perhaps we are already phasing in and out of the 4th dimension without knowing.
Particles that decay really *do* decay at a much slower rate if they are moving quickly. This is an effect that people really have measured in the laboratory.
That said, this *is* a function of how we are doing the observing. It's not a limitation of our measuring equipment... it's a function of the difference in speed between the particle and us. If you could travel at the same speed as the particles, you'd measure the same rates of decay as for particles that seem stationary.
Alright, I'll try to read more first.
And yes, my bad, I totally missed the first sticky.
Any case, thanks =)
jakesee said:
Hi,
Note that I did not use the word "appear" in my response.
If you mean due to some observational error or optical illusion, then that is wrong. Once you correct for light travel times, etc., then the measured rate of a moving clock will really be slower than the identical clock at rest.
What relativity predicts is that moving clocks (and any process that behaves like a clock) will be measured as running slowly according to the observer's clocks. (It is a bit sloppy to say that clocks "really" slow down, since you must specify according to who.) That is definitely what relativity predicts, and time dilation has been confirmed in every test so far.
I'm not sure what you mean. You have one set of folks, with their clocks and measuring devices, making observations of a moving clock. So sure, the observers are moving with respect to the observed!
:bugeye: :confused:
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
