Soft/Stable Movement for Parallelogram Mount with Wheel + Printhead
  • Thread starter Thread starter mc_09
The discussion centers on enhancing the smooth movement of a parallelogram mount for a printhead, specifically addressing stabilization and shock absorption. The design involves a polyurethane wheel to maintain a consistent gap between the printhead and concrete, but concerns arise about potential rattling and vibration during operation. Suggestions include using dashpots for controlled damping and shock absorption, with a recommendation to provide sketches and details for better hardware selection. The importance of proper mounting for springs or dashpots is emphasized to prevent the printhead from slamming down. Overall, the thread seeks practical hardware solutions to achieve a stable and soft engagement with the concrete surface.
mc_09
TL;DR Summary
Designing a parallelogram-mounted printhead that prints onto concrete. Adding a 6" polyurethane wheel to maintain a 0.25" gap and allow smooth movement. Looking for advice on how to prevent vibration/slamming when the wheel contacts the surface — considering springs or dampers, but open to better ideas. Need specific hardware recommendations and mounting tips.
I'm a design engineer, but admittedly not very experienced in mechanical systems. I'm currently working on a project where I need to add smooth, soft movement to a parallelogram mount that supports a printhead. I could really use some guidance from more mechanically savvy folks.
Project Overview:
  • The printhead is mounted to a parallelogram-style arm and will be printing downward onto a sheet of concrete
  • I'm planning to add a 6" diameter polyurethane wheel (labeled Part E in blue) to allow for a smooth transition as the printhead engages with the concrete surface
  • The wheel should keep a consistent 0.25" gap between the printhead and the top of the concrete.
  • The wheel will likely be mounted using an adapter plate (Part D in yellow), which connects to the back of the printhead and also supports the wheel
What I need help with:
1. Stabilizing the Mechanism:
  • When the wheel hits the concrete and lifts the printhead, I want to avoid any rattling or vibration in the mounting.
  • I'm worried about the printhead "slamming down" if the joints are loosened to allow adjustability.
  • Ideally, I want some form of damping or soft control when the wheel engages with the concrete
2. Ideas I'm Considering:
  • I was thinking of adding springs to absorb shock and provide controlled lift/drop but I’m unsure where to mount them or if this is the best option.
  • Open to alternative suggestions
Please provide specific hardware suggestions – part numbers, Amazon/McMaster-Carr links, or product names.
I've labeled all the parts (A–E) for easier reference in the comments/discussion.
Thanks in advance! Happy to provide sketches or more details if needed.
EDIT: I uploaded a back side image a bit more refined
Search dashpots in McMaster-Carr. Dashpots are designed to slow something down for a soft landing. You will need some sort of bracket on your adaptor plate and another bracket on the fixed part of the assembly. If you sketch something up, and provide the drop distance and moving mass, we can help you select the right part. Here's a link: https://www.mcmaster.com/products/dashpots/.
For those not familiar with McMaster-Carr, they are an essential resource for anybody who is looking for information on small mechanical parts.
Likes Lnewqban and berkeman
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
