Solar Panel that you can see through?
  • Thread starter Thread starter davel
    Solar Solar panel
Transparent solar panels are indeed possible, known as transparent solar cells, which allow visible light to pass through while capturing non-visible wavelengths for energy generation. These cells absorb light primarily outside the visible spectrum, enabling them to function without distorting colors. However, this design results in lower efficiency since most sunlight is allowed to pass through rather than being converted to electricity. Despite this inefficiency, transparent solar cells can be advantageous for applications like tinted windows. Overall, they represent a promising innovation for integrating solar technology into everyday surfaces.
davel
can you tell me if it is possible to make a solar panel that will let some light through and still capture the wavelength that makes electricity? or better yet see through.
you need to get the energy by absorbing light at wavelengths that are mostly not within the visible spectrum, and let the photons in the visible spectrum pass through, mostly unimpeded and without applying weird filtering that makes the colors look off.
Of course, that will make it inefficient, as the eye evolved in order to see best with the sunlight, so you're letting most of the energy pass through.
I this case "inefficient" is good if you're wanting a dark/tinted window anyway.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
