Solenoid and toroid inductance puzzle
The discussion revolves around the complexities of calculating the inductance of solenoids, particularly when introducing air gaps into toroidal designs. The original poster questions the validity of established equations for inductance, noting that the presence of air significantly alters the magnetic circuit and the resulting B field. Participants clarify that while traditional equations may not account for these gaps accurately, adjustments can be made to better reflect the magnetic properties of the materials involved. They emphasize that the inductance calculations must consider both the iron and air components, leading to a more nuanced understanding of magnetic energy distribution. Ultimately, the conversation highlights the need for careful consideration of magnetic circuits in engineering applications.
phy5m2w
Im working with building a reluctance motor and I've posed a problem to myself that i cannot answer without questioning some long accepted facts about the inductance of a solenoid.
The simple solenoid and toroidal solenoid are two shapes that seem to have simple equations for calculating the inductance/B field.
e.g:
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/indtor.html
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/indsol.html
for my puzzle see attachment...
Panel 1:
I start with the inductance of a toroid, a completed magnetic circuit which has a inductance and B field for which I agree with the online equation as quoted.
Panel 2:
I add an airgap in the toroid. The magnetic circuit now has a break in it, so the complete circuit needs to take into account for the air and the iron that it passes through. This is done using the reluctance of the two materials, the metal and the air. the result presented as i understand it, now 1/4 of the flux path is in air.
Panel 3:
A 'simple' solenoid where over half the flux path must be through the air. since the relative permeability of the air is so much smaller this part should be the dominent term. making the B field considerably smaller than the value normally quoted!
I have not neglected to include effects of the obvious change in area that the flux is passing through when it is not 'confined' to the metal, so this is oversimplified... BUT this does not explain away the piece of physics that I am questioning here.
Have I made a foolish mistake here or has virtually every physicist/engineer in history learned something that's fundamentally wrong? which i find hard to believe.
This has confused me for far too long, which is it?
Woody
The inductance of a gapped toroid can be calculated by equating the stored electrical energy ½LI2 and the stored magnetic energy ½∫BH dV:
\frac{1}{2}LI^2=\frac{1}{2}\int_V BHdV = \frac{\mu\mu_0}{2}\frac{A_i_r_o_nN^2I^2}{\ell_i_r_o_n}+\frac{\mu_0}{2}\frac{A_g_a_pN^2I^2}{\ell_g_a_p}
where H=NI/\ell and B = μH in gap and μμ0H in iron, Airon and Agap are the cross sectionional areas of the flux, and volume V =2 πrA, and 2\pi r = \ell_g_a_p + \ell_i_r_o_n. Rewriting, we get
L = \mu_0N^2[\frac{\mu A_i_r_o_n}{\ell_i_r_o_n}+\frac{A_g_a_p}{\ell_g_a_p}]
Agap is larger than Airon because Blongitudinal is continuous in the iron and gap, while Hparallel is continuous across the iron-gap boundary.
This leades to "refraction" and Snell's Law across the iron-gap boundary, just like light in glass.
Bob S
So.. If we imagine that lgap is very small, then the equation should become equal to the original toroid equation. Agap will approximately equal to Airon. So... the second term in that equation appears to blow up rather than diminish to zero as should be expected.
and yes... I had an equation that produced that mistake at some point, which I think is in part what lead me to the original problem described.
You are right. The correct solution is shown in the thumbnail. Basically, although
\int_C H d\ell = NI
H is not continuous around the loop C, so H≠ NI/ l. Only B is continuous. Equation (5) in the thumbnail shows the correct result.
Bob S
So... back to my original question:
Does this imply that the inductance of a solenoid, frequently quoted in textbooks, is actually wrong? as in panel 3 in my original post
Calculating the inductance of a solenoid with iron is very difficult, but for a magnetic circuit with a small gap like the thumbnail in my previous post, the calculation is the following. Use the relation
\frac{1}{2}LI^2=\frac{1}{2\mu\mu_0}\int_VB^2\;dV_v_o_l=\frac{1}{2\mu\mu_0}\int_VB^2\;dV_i_r_o_n+\frac{1}{2\mu_0}\int_VB^2\;dV_g_a_p
for the stored energy in the iron and a small gap, and use (from the thumbnail in my previous post)
B=\frac{\mu\mu_0NI}{\ell_i_r_o_n+\mu\ell_g_a_p}
for the magnetic field in both the iron and the gap. Here, \ell = \ell_i_r_o_n +\ell_g_a_p. Turn the crank and get an expression for the inductance L.
This does not correctly handle the fringe field in the gap for a large gap, but an adjustment in the cross sectional area in the gap should improve the accuracy.
In an air-filled solenoid, half the stored magnetic energy is inside the solenoid, and half outside. For a solenoid with the interior filled with iron, nearly all the magnetic energy is outside.
Here is the on-axis field inside a short air-filled solenoid.
http://www.netdenizen.com/emagnettest/solenoids/?solenoid
For short air-filled solenoids (single-turn loops), you should look at Smythe Static and Dynamic Electricity (Third Edition) page 339. For N turns, multiply by N2.
[added] For the integration, use V_i_r_o_n=A_i_r_o_n\ell_i_r_o_n\;\;and\;\;V_g_a_p=A_g_a_p\ell_g_a_p
For small gaps, \;\;\;A_i_r_o_n=A_g_a_p
Bob S
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
