rml701
- 1
A cubical block of wood 28cm on an edge floats in water with face down. It is depressed slightly and released, whereupon it bobs with a period of 1.35 seconds.Find the specific gravity of the wood.
Determining the specific gravity of a cubical block of wood in water is a relatively simple process. First, measure the mass of the block using a scale. Then, fill a container with water and measure the mass of the container and water. Next, submerge the block in the water and measure the combined mass of the block and water. Finally, use these measurements to calculate the specific gravity using the formula: Specific Gravity = (Block Mass / (Block Mass + Water Mass))
The specific gravity of a material is an important physical property that can help determine the density and composition of the material. This information can be useful in a variety of industries, such as construction, manufacturing, and research.
The specific gravity of a cubical block of wood in water can be affected by several factors, including the type of wood, the moisture content of the wood, and the temperature of the water. Additionally, any air pockets or imperfections in the block can also impact the specific gravity measurement.
The specific gravity of a material in water is typically lower than its specific gravity in air. This is because water has a higher density than air, and therefore exerts more buoyant force on the block, making it appear lighter. However, the difference in specific gravity between the two mediums can also depend on the density of the material.
It is important to take proper safety precautions when handling materials and using equipment in any scientific experiment. Wear protective gear, such as gloves and goggles, when handling the wood and water. Additionally, be sure to properly dispose of any materials used in the experiment to avoid any potential hazards.
