Solution of exponential equation
  • Thread starter Thread starter techiejan
    Exponential
The equation βe^(x/β) - x = β + (A/B) simplifies to x = √(2A/βB) when β is large. The exponential e^(x/β) is expanded to the first three terms because, with a large β relative to x, higher-order terms become negligible. This simplification allows for an easier calculation of x while maintaining reasonable accuracy. For more precise results, additional terms in the expansion can be included. The discussion highlights the importance of term selection in approximating solutions to exponential equations.
techiejan
How does the given equation:
βe^(x/β)-x = β+(A/B)
solves to x = √(2A/βB) when β is large?
Mathematics news on Phys.org
Expand e^{\frac{x}{\beta}} to the first three terms.
Thanks grzz, I solved it now. Can you please tell me the logic behind expanding the exponential to first three terms?
The expansion of e^{\frac{x}{\beta}} consists of powers of \frac{x}{β}.
Since β is large (compared with x) then we can include only the first three terms of the expansion since the other terms would be very small and would not change the value of x.
Of course, if one wants a more accurate value of x, one must include more terms in the expansion.
Thanks grzz. This was very helpful.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
