Solution of homogeneous question
  • Thread starter Thread starter nhrock3
    Homogeneous
nhrock3
x and y are solutions to an equation system
i know that if x and y are solutions to a homogeneous system then for any a b
ax+by (linear diversity) is also a solution
but does it go the other way around to
if x and y are solutions and ax+by also then its a homogeneus system
You can check this yourself. Assuming that the system is linear, then we can write
\hat{A} x = \alpha ,
where \hat{A} is a linear operator and \alpha is a number, not necessarily zero. There is a similar equation for y, since it's also a solution. Now operate on the linear combination and determine if your question is true.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
