Chemistry How Can You Determine Which Layer Is Which Without Using Densities?
Determining which layer is which without using densities can be achieved through various methods, including analyzing boiling and freezing points. However, the most straightforward approach is to add a drop of water to the mixture. This method reveals which layer mixes with the water, indicating the aqueous layer versus the organic layer. The organic layer is typically already saturated with water, while the aqueous layer can be diluted. This technique provides a clear and practical solution for layer identification.
fishfish
How would you determine which layer is which without using the densities?
I can think of several ways.
Boiling point
freezing point
But the easiest by far is to just add a drop of water and see which layer it mixes with, since you have an organic layer already saturated with water, and an aqueous layer you can always dilute.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
