Solutions to differential equations
nick.martinez
y(x)=A*e^(λx) ; y'=λy
attempt at solution:
y'(x)= Ae^(λx)*λ
λy= Ae^(λx)*λ
divide by λ, which cancel. then i get:
y=Ae^(λx)
i want to say the differential equation holds but the issue i see is that y' and y'(x) are not equal derivatives, so my final answer is that the differential equation does not hold. what do you guys think?
$$ y=\text{Ae}^{\text{$\lambda $x}}\text{ } $$
Latex accident! Will repost later today :)
So you want to show that y(x)= Ae^{\lambda x} is the general solution to the differential equation y'= \lambda y or that it is a solution? The first is harder than the second! I don't understand what you mean when you say " y' and y'(x) are not equal derivatives". They are just slightly different ways of writing exactly the same thing- the first just doesn't have the "(x)" which is assumed since y is a function of x.
But your "proof" is a little over complicated. All you need is
If y= Ae^{\lambda x} then y'= A\lambda e^{\lambda x}= \lambda (A e^{\lambda x})= \lambda y.
when i say y' I am referring to the equation y'=λy and also refferring to y'(x)=Ae^(λx)*x in my example. i know they are both the same. Do the two equations i listed above look equal to each other?
There's a typo here. I think you mean y'(x) = Aλeλx.
Equations are not "equal" to each other. Equations can be equivalent, which means they have the same set of solutions.
For your differential equation y' = λy, it can be shown that all solutions are of the form y = Aeλx. If you differentiate the latter equation, you get y' = Aλeλx = λy.
So in this case I can set y' and y'(x) equal to each other even though when I take the derivative of y(x) i get y'(x)=Ae^(λx)*λ which does not equal y' = λy? Again I did set them equal to each other and got the original y(x). So this is a solution to a diff eq.
You've got me really confused. If y= Ae^{\lambda x} then y'= A\lambda e^{\lambda x}= \lambda(Ae^{\lambda x})= \lambda y They are exactly the same!
Thanks I wasn't thinking never mind. Thanks for the clarification.
