Solve Battery Parallel Problem: Get Help Now
  • Thread starter Thread starter pantera1441
    Batteries Parallel
The discussion focuses on solving a battery parallel circuit problem using nodal equations and Kirchhoff's Current Law (KCL). The key steps involve determining the node voltage (V_x) and calculating the currents through the resistors based on voltage drops. The solution reveals that V_x is 12.9V and the current through the leftmost resistor is 0.784A. Participants emphasize the importance of understanding the principles behind the calculations rather than just obtaining the answer. The conversation also touches on strategies for tackling similar problems in the future, particularly when multiple batteries are involved.
pantera1441
anyone help me out with this probelem?
What you want to do is to attack this problem by using nodal equations, as you can see from the drawing this circuit has only one node placed in the junction between the three resistors, you can start by assuming the following:
1. By KCL the current at the node is equal to 0
Since we don't know anything about the direction of the currents, we can safely let the node voltage determine the direction.
2. Let the V_{x} denote the node voltage
Let I_{1} denote the current from 28.3 V source
Let I_{2} denote the current from 14.15 V source
Let I_{3} denote the current in the 16.5Ohm resistance
3. Applying the nodal equations we get the following:
I_{1}+I_{2}+I_{3}=0
Note that the current can take any direction. Now we replace currents with voltage drops divided by resistor values:
\frac{V_{x}-28.3}{30.6}+\frac{V_{x}-14.15}{4.32}+\frac{V_{x}}{16.5}=0
Solving for V_{x} we get 12.9
Now we can solve for the current in the leftmost resistor:
I_{3}=\frac{V_{x}}{16.5}=0.784A
DONE!
thanks a lot for the help...
much obliged!
much obliged!
No problem, I hope you understood the steps towards the solution.
Yeah, you use KCL bc all the current is conserved, and you find the actual current that enters the bottom resistor, after that you can find the current across any of the resistors, using the way you set it up
In the future, it is better to not just do the problem for the OP but to give little hints to push him/her in the right direction...
Correct and remember if the batteries were switched the other way around, then you would use V_{x}+V_{battery} instead
I won't argue about that, but i thought that making the complete description of the steps including the description of what rules i applied would help him better, so he/she will know what to do next time he/she is faced with the problem.
do you think you can "push me in the right direction" on this one, I know they're looking for the difference between A and B, but i forget how to do the voltage drop and I'm clueless when there's more than one battery
Hehe, shure. First you have to determine the current flowing through the loop, note that the current will be the same at all places. When You've determined the current in the loop, start by writing the equation expressed as voltage drops , you should start at point a and move towards point b, note that the first voltage drop across the battery will be negative, since you're moving from -to +, and it will be positive across the resistors and positive across the battery that is near the b point, since the battery is going from + to -.
do you mean a positive drop...I know the current is 3.614mA, and that it drops almost 16V in between the two batteries, but what do I do about the negative voltage on the other side of the bottom right battery, add it to get a negative number?
I tried 40.86V and that was wrong, is it 25V - 15.86V = 9.14V as the difference
As all the components are in series you can rearrange the circuit to group all the cells and all the resistors.
This should make it easier to work out the circuit voltage and hence the current.
got it...take the current of -3.614mA and multiply it by the 2 resistors added together on the bottom to get -15.86V
Thanks,
You'll be hearing from me again this week about RC Circuits...totally new to me
LOL, ok ;)
