Solve for t: Rearrange Equation σ=ωi*t+½α*t^2
  • Thread starter Thread starter oj600
To solve for t in the equation σ = ωi*t + ½α*t², it is essential to recognize that this is a quadratic equation in the form of at² + bt + c = 0. The correct approach involves rearranging the equation to standard form, which leads to t² + (2ωi/α)t - (2σ/α) = 0. The quadratic formula can then be applied to find the values of t. Simplifying the equation incorrectly can lead to errors, as dividing only one part of the equation alters its integrity. Properly applying the quadratic formula will yield the correct solutions for t.
oj600
I need to find t in the following:
σ = ωi*t + ½ α*t2 (this is ment to be t squared)
I got:
t + t(squared) = 2 * σ/(ωi * α)
is this then simply
t = sqrt(2 * σ/(ωi * α)) ??
σ = ωi*t + ½ α*t^2
You can't write this as:
t + t^2 = 2 * σ/(ωi * α)
You can't divide only 1 half of the equation by something... then you'll just change it.
Like dividing by 1/2 a would give:
t^2 + 2ωi/a*t = 2σ/a
You just can't simplify it like you do.
And your third step is not correct either.
This is a Quadratic Equation ( http://en.wikipedia.org/wiki/Quadratic_equation ), look up how to solve these (you could make use of the quadratic formula).
Quadratic Formula:
[PLAIN]http://dl.dropbox.com/u/4645835/MATH/Quadratic.gif
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
