Solve Inequalities with Traditional x^2 or x^4
  • Thread starter Thread starter hwmaltby
The discussion revolves around solving the inequality a^2 + b^2 + c^2 + d^2 + ab + ac + ad + bc + bd + cd ≥ 10, given that abcd = 1 for positive variables a, b, c, and d. The Arithmetic Mean-Geometric Mean (AM-GM) inequality is highlighted as a key tool for proving this inequality. Participants suggest applying AM-GM to both the squares and the products of the variables to derive the required result. The conversation emphasizes the importance of recognizing the right approach when tackling algebraic inequalities. Ultimately, the problem is resolved through the application of AM-GM to all relevant terms.
hwmaltby
Hello!
I normally consider myself fairly decent with algebra, but when it comes to inequalities... Well, I cannot even solve this very simple one, so please help me!
I have been (somewhat) studying inequalities for the past few days, but I cannot find a theorem that deals with changing from quadratics to quartics (by this I mean two variables multiplied together and four variables multiplied together -- not the traditional x^2 or x^4) as is required by this problem:
Show that for positive a, b, c, and c, such that abcd=1, a^2 +b^2+c^2+d^2 + ab+ac+ad+bc+bd+cd is not smaller then 10.
I think it's fairly clear we need to prove:
a^2 +b^2+c^2+d^2 + ab+ac+ad+bc+bd+cd >= 10abcd=10
If you use any theorems, please mention what they are called. If you derive everything from scratch, all the better!
Thank you for any help or hints you can give me!
Mathematics news on Phys.org
Oh, there is an general easy trick. Think of the inequality between the arithmetic and geometric mean.
Let me know if you need more hints ;)
PS: What you think is "fairly clear" is close, but not quite what you will need :)
Yes, I suppose I forgot a square root sign... That solves my "quartic" problems.
Square root sign? Actually there is no need for a modification.
In general \frac{\sum a_n}{N}\geq \sqrt[N]{ \prod a_n}
If the product happens to be a constant, it simplifies a lot.
And note that you can use tricks to make the product a constant!
For example
a^2+\frac{1}{a}=a^2+\frac{1}{2a}+\frac{1}{2a}
and there we go again... :)
Oh, I got it! Thank you for your help.
I did it by applying AM-GM to a^2, b^2, c^2, and d^2 and again to ab, ac, ad, bc, bd, and cd. I then added them together.
If there is a more elegant way, could you share it?
Once again, thank you for your help!
The simplest is to apply
\sum a_n\geq N\sqrt[N]{\prod a_n}
straight to all 10(!) terms ;)
Oh, you're right! Wow, I feel extremely stupid now. Well, thank you for all this!
Oh, don't worry. It happens to all of us that if you get stuck on the wrong track it's hard to switch to a different idea. Your initial idea was close and tempted you to see it a particular way.
