Solve Momentum Question: 2000 kg Hammer and 400 kg Stake
  • Thread starter Thread starter Firestrider
    Momentum
In a discussion about a momentum problem involving a 2000 kg hammer striking a 400 kg stake, participants clarified that the collision is completely inelastic, meaning the hammer and stake move together post-collision. The correct approach involves using the conservation of momentum to find the velocity of the combined mass after impact, which is calculated to be 5 m/s. The kinetic energy before the collision is not conserved due to energy loss in an inelastic collision, and participants debated the correct method for calculating the work done and the resulting force on the stake. Ultimately, the force calculations varied, with some arriving at values around 64 kN, while others reached different conclusions based on their interpretations of energy conservation. The key takeaway is that inelastic collisions require careful consideration of momentum and energy dissipation.
Firestrider
My teacher showed me a question he was confused on with a picture so I don't know the original word problem, so I'll make one up: A 2000 kg hammer strikes a 400 kg stake into the ground. The velocity of the hammer is 6 meters per second and the stake goes into the ground .75 meters. What is the velocity of the stake after the hammer strikes it and what is the resistant force? This is a completely inelastic collision.
This is what I did:
m_{1}v_{1} + m_{2}v_{2} = m_{1}v_{1}' + m_{2}v_{2}'
v_{1}' = v_{2}'
v_{2}' = \frac{m_{1}v_{1} + m_{2}v_{2}}{m_{1} + m_{2}}
v_{2}' = \frac{2000(6) + 400(0)}{2000 + 400}
v_{2}' = 5 m/s
\Delta W = Fd
\Delta W = \Delta PE + \Delta KE
\Delta KE = \frac{1}{2}mv^2
\Delta KE_{hammer} = \frac{1}{2}2000*(6)^2 = 36000 J
\Delta PE = mgh
\Delta PE_{stake} = 400*9.8*.75 = 2940 J
\Delta W = 36000 + 2940 = 38940 J
F = \frac{\Delta W}{d}
F = \frac{38940}{.75}
F = 51,920 N
That's what I got, but it isn't the right answer, what am I doing wrong here?
Oh you I forgot to put that this is a completely inelastic collision.
If v'_{1} = v'_{2}, then this implies that the hammer and the stake combine to become one object after the collision. Therefore to calculate the kinetic energy you need to use the sum of the masses of the hammer and stake. I am also confused to why you have used the velocity of six m\cdot s^{-1} when you've just calculated to be 5 m\cdot s^{-1}?
Oh I was using the velocity of the hammer before it hit the stake to get kinetic energy. Should I take the sum of kinetic energy of the hammer & stake after the collision plus potential energy of the stake before the collision to find the work? I probably worded my question wrong.
Would it be correct to say that for the hammer to completely stop after the collision it would have to be going 30 m/s?
Yep, that sounds about right.
You've found the velocity of the combined body, because it stated that v'_{1} = v'_{2}
So you know that the kinetic energy upon collision is given by;
E_{k} = \frac{1}{2}mv^2 = \frac{1}{2} (6000+400) v'_{2}^{2}
Ok I get 30000J for the sum of the kinetic energies and subtract 2940J potential energy. 27060/.75 = 36,080N. But that is not what the book says.
I'm confused on the label you used: m\cdot s^{-1} is that worded " meters in one second ". Then how would you word m\cdot s ? I don't get why you would use " inverse seconds "
What answer does the book give? Working it out I get about 169kN.
The answer in the book gives 64kN
What if you assume the hammer become stationary after the collision?
m\cdot s^{-1} = \frac{m}{s}
Which is metres per second. :smile:
I get 240kN if the hammer becomes stationary after collision.
I get 63520 N so it must be right.
You just have to take into account the motion of both stake and hammer after the collison. In the kinetic energy and in mgh, use mass= total mass.
Then it works out.
Patrick
Then it works out.
Patrick
Correction, I get the same as you 63544N. I was looking at another thread in which the mass of an object was 6000kg, so I was using 6000kg instead of 2000kg :blushing: .
Just to clarify for the OP;
WD = \frac{1}{2}\Sigma m \cdot v'_{2}^{2} + \Sigma m \cdot gh
Sorry about the confusion.
-Hoot:smile:
Do you have the correct answer now firestrider?
Ok thanks for all the help. That's what I got too. But why don't I have to take in account the kinetic energy of the hammer before the collision?
You stated that the collision is totally inelastic, which means the kinetic energy of the objects is not conserved, however, momentum is always conserved. Basically, you could split the question up into three sections. You took the velocity of the hammer into account when you used momentum, you can't use energy because the collision isn't elastic.
Does that make sense?
Because when the collision occurs, some energy is dissipated in heat and used to deform the objects, etc. This is an inelastic collision, so kinetic energy is not conserved (you actually have all the numbers to calculate the change of kinetic energy during the collision...that number corresponds to energy dissipated in the forms I mentioned above). You have to start from the total kinetic energy after the collision and work from there.
Patrick
EDIT: After posting I saw that Hootenanny had basically said the same thing.
