Solve the equation (sin and cos problems)
  • Thread starter Thread starter jegues
    Cos
The discussion revolves around solving the equation 100sin(α) - 400cos(30° - α) = 210. Participants simplify the equation using trigonometric identities but encounter difficulties in isolating α. One user suggests expressing the equation in the form Rsin(α + A) to facilitate solving for α, leading to a potential solution of α = 73.9°. However, further calculations reveal that this value does not satisfy the original equation, prompting a reevaluation of the approach. Ultimately, the correct solution is found to be α = -109.5° + 360°k, indicating a general solution.
jegues
Solve the equations:
100sin(\alpha) -400cos(30^{o}-\alpha) = 210
cos(A-B)=cos A cos B + sin A sin B
I threw the identity into the original equation, simplified a bit now I'm stuck at the following:
200sin(\alpha) -400\sqrt{3}cos(\alpha) - 400 sin(\alpha) = 420
\Rightarrow 10sin(\alpha) -20\sqrt{3}cos(\alpha) - 20 sin(\alpha) = 21
Any ideas?
Any ideas?
200sinα-400sinα simplifies to?
\Rightarrow -10(sin(\alpha) + 2\sqrt{3}cos(\alpha)) = 21
Slowly getting there... Anymore nudges in the right direction?
I can make things into an uglier equation ;),
\Rightarrow sin(\alpha) + 2\sqrt{3}cos(\alpha) = \frac{-21}{10}
but that really doesn't get me anywhere either... I have a feeling I may have taken the wrong route from the get go.
Put the ledt side in the form Rsin(α+A) or Rcos(α-A)
a sin \theta + b cos \theta \equiv R cos \alpha sin \theta + R sin \alpha cos \theta So,
For sin\theta, 1=Rcos\alpha
For cos\theta, 2\sqrt{3}=Rsin\alpha
So,
2\sqrt{3} = tan\alpha
So,
\alpha = 49.1^{o}
Is this correct?
EDIT: I'm lost in how to use the form Rsin(\theta\pm\alpha), could you show me how to apply it ?
So,
So,
\alpha = 49.1^{o}
Is this correct?
Yes that looks correct, and what is R=?
R would simply be as follows,
R = \sqrt{a^{2} + b^{2}} = \sqrt{13}
But,
\alpha = 49.1^{o}, doesn't seem to be satisfying my original equation? Thoughts?
But,
tanα=2√3 ⇒α=tan-1(2√3)=73.9° (re-check that)
Even with \alpha = 73.9^{o}, my original equation still isn't being satisfied.
Sorry your notation confused me. I used 'A' for a reason. A=73.9°. Your equation is now
√13sin(α+73.9°)= -21/10
You need to be more careful. You have
and the identity
But the \alpha in the first line isn't the same as the \alpha in the identity. Compare what you have to the LHS of the identity to see how the various quantities match up.
Sorry if I'm wrong, but won't this lead me in circles?
sin(A+B)=sin A cos B + cos A sin B
Ill be back to having an equation with a
sin\alpha,cos\alpha,
making it just as hard as the original to solve no?
Solve for \alpha+73.9^\circ.
If you have
√13sin(α+73.9°)= -21/10 and then divide by √13, then you will have
sin(α+73.9°)= -21/10√13
Now just do as vela suggests and solve for α+73.9° and get α.
Also, your initial question did not state the domain of α. Are you to find a general solution or did you leave out the the range for your answer(s)?
\alpha+73.9^\circ
Can I simply use sin^{-1}, to move the sin to the other side of the equation?
If so,
\alpha = -109.52^{o}
... Turns out this works! Pefect! Thank you both for all your help it's appreciated!
The question only states "Solve the equations:" and nothing else, so I'm assuming it's a general solution.
Is it valid to write this as an answer?
\alpha = -109.5^{o} +360^{o}k,\forall k Z,
I'm just not sure how to state the "for all integers k" part...
Bump, just looking for some final clarification on my notation.
