MHB How Can You Solve Complex Trigonometric Equations?
The discussion revolves around solving the complex trigonometric equation involving sine and cosine functions. Participants share their solutions and express camaraderie through light-hearted banter. One contributor acknowledges another's correct result while presenting their own similar solution. The tone remains playful, with comments reflecting a mix of frustration and humor about the complexity of the problem. Overall, the thread highlights collaborative problem-solving in trigonometry.
anemone
MHB
POTW Director
Solve the equation
$$\sqrt{3}\sin x(\cos x-\sin x)+(2-\sqrt{6})\cos x+2\sin x+\sqrt{3}-2\sqrt{2}=0$$
Mathematics news on Phys.org
anemone said:
Solve the equation
I'm beginning to think that you are a sadist...
-Dan
Here is my solution:
We are given to solve:
$$\sqrt{3}\sin(x)(\cos(x)-\sin(x))+(2-\sqrt{6})\cos(x)+2\sin(x)+\sqrt{3}-2\sqrt{2}=0$$
First, let's do the distribution dance...
$$\sqrt{3}\sin(x)\cos(x)-\sqrt{3}\sin^2(x)+2\cos(x)-\sqrt{6}\cos(x)+2\sin(x)+\sqrt{3}-2\sqrt{2}=0$$
Now, regroup...
$$\sqrt{3}(\sin(x)\cos(x)+1-\sin^2(x))+2(\sin(x)+\cos(x))-\sqrt{6}\cos(x)-2\sqrt{2}=0$$
Within the second factor of the first term, apply a Pythagorean identity:
$$\sqrt{3}(\sin(x)\cos(x)+\cos^2(x))+2(\sin(x)+\cos(x)-\sqrt{2}-\sqrt{6}\cos(x)=0$$
Now factor:
$$\sqrt{3}\cos(x)(\sin(x)+\cos(x))+2(\sin(x)+\cos(x)-\sqrt{2}(\sqrt{3}\cos(x)+2)=0$$
$$(\sin(x)+\cos(x))(\sqrt{3}\cos(x)+2)-\sqrt{2}(\sqrt{3}\cos(x)+2)=0$$
$$(\sin(x)+\cos(x)-\sqrt{2})(\sqrt{3}\cos(x)+2)=0$$
The second factor has no real root, hence we are left with:
$$\sin(x)+\cos(x)=\sqrt{2}$$
$$\sin\left(x+\frac{\pi}{4} \right)=1$$
$$x+\frac{\pi}{4}=\frac{\pi}{2}+2k\pi$$ where $$k\in\mathbb{Z}$$
$$x=\frac{\pi}{4}+2k\pi=\frac{\pi}{4}(8k+1)$$
Now, regroup...
Now factor:
Thank you MarkFL for participating and your result is correct!:D
My solution is quite similar to yours but I figure it is only fair if I posted mine as well here...
My solution:
We're given
I noticed there is another term $$(2\sin x)$$ which I could group it to the first term, after I multiplied $$\sqrt{3}$$ onto everything inside the parentheses...
$$\sin(x)(\sqrt{3}\cos(x)-\sqrt{3}\sin(x)+2)+(\sqrt{2}\sqrt{2}-\sqrt{2}\sqrt{3})\cos(x)+\sqrt{3}-2\sqrt{2}=0$$
Also, the second term can be simplified further to get
$$\sin(x)(\sqrt{3}\cos(x)-\sqrt{3}\sin(x)+2)+\sqrt{2}\cos(x)(\sqrt{2}-\sqrt{3})+\sqrt{3}-2\sqrt{2}=0$$
And we can rewrite$$\sqrt{3}$$ as $$(\sqrt{3})(1)=\sqrt{3}\left(\sin^2(x)+\cos^2 (x) \right)=\sqrt{3}\sin^2(x)+\sqrt{3}\cos^2(x)$$ and observe that each of these two terms can be simplified out by collecting them to the first and second terms of the equation above:
$$\sin(x)(\sqrt{3}\cos(x)-\sqrt{3}\sin(x)+2)+\sqrt{2}\cos(x)(\sqrt{2}-\sqrt{3})+\sqrt{3}\sin^2(x)+\sqrt{3}\cos^2(x)-2\sqrt{2}=0$$
$$\sin(x)(\sqrt{3}\cos(x)-\sqrt{3}\sin(x)+2+\sqrt{3}\sin(x))+\sqrt{2}\cos(x)\left(\sqrt{2}-\sqrt{3}+\frac{\sqrt{3}}{\sqrt{2}}\cos^2(x) \right)-2\sqrt{2}=0$$
$$\sin(x)(\sqrt{3}\cos(x)+2)+\sqrt{2}\cos(x) \left(\frac{2-\sqrt{2}\sqrt{3}+\sqrt{3}\cos(x)}{\sqrt{2}} \right)-2\sqrt{2}=0$$
$$\sin(x)(\sqrt{3}\cos(x)+2)+\cos(x)(2-\sqrt{2}\sqrt{3}+\sqrt{3}\cos(x))-2\sqrt{2}=0$$
$$\sin(x)(\sqrt{3}\cos(x)+2)+\cos(x)(\sqrt{3}\cos(x)+2)-\sqrt{2}\sqrt{3}\cos(x)-2\sqrt{2}=0$$
$$(\sqrt{3}\cos(x)+2)(\sin(x)+\cos(x))-\sqrt{2}(\sqrt{3}\cos(x)+2)=0$$
$$(\sqrt{3}\cos(x)+2)(\sin(x)+\cos(x)-\sqrt{2})=0$$
At this point, I think we can just refer to your post on how to solve for the values for $$x$$.
-Dan
Well, I'm usually pretty hard on myself...:o(Tongueout)
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
