Solve X'+2X'+(\lambda-\alpha)X=0 | Chris Struggling
  • Thread starter Thread starter Chris_K
    Eigenvalues Lost
Chris_K
I'm having trouble getting started on this problem... I just really don't understand what to do.
Solve
X'+2X'+(\lambda-\alpha)X=0, 0<x<1
X(0)=0
X'(1)=0
a. Is \lambda=1+\alpha an eigenvalue? What is the corresponding eigenfunction?
b. Find the equation that the other eigenvalues satisfy.
I appreciate any help you can give me!
Thanks,
Chris
are u sure that the edo is correct?
you have there a linear second order d.o with constant coeficients and initial values, so your solution will be some linear comb. of exp[rt] (you have to calculate r of course).
i don't really understand why would you end with an eigenvalue problem in this way but maybe I am not well informed.
Yeah, everything on there is correct. I'm not sure what you mean though...
nm... figured it out.
X''+2X'+(\lambda-\alpha)X=0
let X=e^{rt} implies
r^2+2r+(\lambda-\alpha)=0
so
r=-1\pm\sqrt{1-(\lambda-\alpha)}
X(t)=Ae^{(-1+\sqrt{1-(\lambda-\alpha)})t}+Be^{(-1-\sqrt{1-(\lambda-\alpha)})t}
X(0)=A+B
so A=-B[/tex]<br /> <br /> X&amp;#039;(1)=A[r_{+}e^{r+}-r_{-}e^{r_{-}}]=0<br /> <br /> A=0 would lead to the trivial solution, so <br /> <br /> r_{+}e^{\sqrt{1-(\lambda-\alpha)}}=r_{-}e^{-\sqrt{1-(\lambda-\alpha)}}<br /> <br /> \lambda=1+\alpha is clearly an eigenvalue<br /> <br /> and \lambda_{m} satisfy the equation<br /> <br /> \frac{-1+\sqrt{1-(\lambda_{m}-\alpha)}}{-1-\sqrt{1-(\lambda_{m}-\alpha)}}e^{2\sqrt{1-(\lambda_{m}-\alpha)}}=1
Thread 'Direction Fields and Isoclines'
I sketched the isoclines for $$ m=-1,0,1,2 $$. Since both $$ \frac{dy}{dx} $$ and $$ D_{y} \frac{dy}{dx} $$ are continuous on the square region R defined by $$ -4\leq x \leq 4, -4 \leq y \leq 4 $$ the existence and uniqueness theorem guarantees that if we pick a point in the interior that lies on an isocline there will be a unique differentiable function (solution) passing through that point. I understand that a solution exists but I unsure how to actually sketch it. For example, consider a...
