Solving 1 + 2cos(2x+ π/3) for Zeroes: Step-by-Step Guide
  • Thread starter Thread starter jasper10
18 replies · 5K views
jasper10
Find the zeroes of
f(x) = 1 + 2cos(2x+ π/3)
Range: (0 ; π)
1 + 2cos(2x + π/3) = 0
hence, cos(2x + π/3) = -1/2
hence, 2x + π/3 = 2π/3
and, x = π/6 which is 30 degrees
can someone help me find the other 0 ?
I don't know how to!
Thanks a lot!
(the answer is x=π/2 but i don't know how to get there!)
First, I don't quite know how you went from your first step to your second, even though it does turn out to be correct. A bit of explanation would be most appreciated.
Second, have you tried using the sum-of-angles formula to expand your cosine out? It might make it easier, I think...
Ok Char. Limit,
I edited my answer and showed the transition step.
What do you mean by "the sum of angles formula" ?
Well, if one looks at the unit circle, one can see that 2*pi / 3 is one place where
cos(y) = -1/2. However, there are more places on the unit circle in which
cos(y) = -1/2. Finally, one can also add 2*pi*n to the result, and end up at
the same place.
the same place.
But he restricted x to be between zero and pi...
The sum-of-angles formula is as follows:
[tex]cos(x+y)=cos(x)cos(y)-sin(x)sin(y)[/tex]
I have no idea how to prove it, but it is a theorem, I believe.
Yes, but still, one can manually inspect the formulas to see when
[tex] 2x + \pi /3 = 2\pi /3 +2\pi n[/tex]
, and after that see if x is inside the interval between 0 and pi.
cos(y) = -1/2.
Yes, my question ultimately is
How does one determine these other places where cos(y) = -1/2 ?
If you are familiar with the unit circle, you have that the x-coordinate on the circle
is cos(x), while the y-coordinate is sin(x). For a picture, please see
http://en.wikipedia.org/wiki/Unit_circle
In the picture, you can see that cos(x) = -1/2 means: at which place at the unit circle
is the x-coordinate equal to -1/2? And there are two places that can happen at in the circle. Does this help?
Well, wouldn't you just have to add pi/4 for the next zero and then 3pi/4 and keep going until you're beyond your range in this case? Since the function is pretty much a squashed together cos curve (twice as many zeros as a normal one) that is half it's amplitude up the y-axis, it's amplitude being 2, that is out of phase of your standard cos curve by pi/3. I'm not sure I'm visualising it right, but I guess you could always sketch it up on some spare sheet.
Correction: cos(y) = -1/2 for y = 2pi/3 or for y = 4pi/3.
Replace y by 2x + pi/3 and you should get two values of x in (0, pi).
It actually makes it much harder.
I stand corrected then.
Mark44 said:
cos(y) = -1/2 for y = 4pi/3 or for y = 5pi/3.
How do you know this?
Mark gave you the values where the cosine is -1/2 in the third quadrant and 1/2 in the fourth quadrant. You're interested in the values where cosine is -1/2, not 1/2.
The first thing you should do is draw a unit circle. Then sketch the places where the cosine is equal to -1/2 and find the appropriate angles. In which two quadrants does your solution lay?
How does one find the place where cosine is equal to -1/2?
and as you said, the solution is in the third quadrant and the first solution (Pi/6) is in the first.
Due to a mental lapse, one of the values I gave was incorrect. The values of y should have been in the second and third quadrants, but not in the fourth. I have corrected my earlier response.
No, [itex]\cos \pi/6=\frac{1}{2}\sqrt{3}[/itex]. Secondly I am not asking you to draw the position where cos is -1/2 in the unit circle exactly. The use in the unit circle is that you can see in which quadrant the solutions lay. When you draw a line radially outwards from the origin you can form a triangle. Which side of that triangle corresponds to the cosine and which one to the sine? To answer your question you want to know where that side of the triangle is -1/2.
There are just a handful of angles that you are expected to know exactly: 0, pi/6, pi/4, pi/3, pi/2, plus their complements and supplements. If you plot these angles in the unit circle, you can use symmetry to show that cos(y) = 1/2 for y = pi/3 and y = 5pi/3, and that cos(y) = -1/2 for y = 2pi/3 or y = 4pi/3.
Ok! thanks, i kind of get it now!
