MHB Solving 16•4^{-x}=4^x-6 Equation
  • Thread starter Thread starter Petrus
    Power
The equation 16•4^{-x}=4^x-6 can be simplified by multiplying both sides by 4^x, resulting in 16 = (4^x)^2 - 6•4^x. Substituting u = 4^x allows for easier manipulation of the equation. By setting 4^x = y, the equation can be solved for y, leading to the final solution for x as x = ln(y)/ln(4). The original poster successfully solved the equation with the provided guidance.
Petrus
Hello MHB,
I am stuck on this equation and don't know what to do, If i take ln it does not work, any advice?
$$16•4^{-x}=4^x-6$$
Regards,
$$|\pi\rangle$$
Mathematics news on Phys.org
Try multiplying both sides by $4^x$. You get:
$$16 = (4^x)^2 - 6 \cdot 4^x$$
Now substitute $u = 4^x$. What do you see? :)
Petrus said:
Hello MHB,
$$16•4^{-x}=4^x-6$$
Regards,
$$|\pi\rangle$$
Set $4^{x}=y$, then solve for y and finally find $x = \frac{\ln y}{\ln 4}$ ...
Kind regards
$\chi$ $\sigma$
Hello,
Thanks for the fast respond and help from you both!:) i succed to solve it with correct answer!:)
Regards,
$$|\pi\rangle$$
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
