How do you solve a 4th degree equation?
  • Thread starter Thread starter nmbr42
    Degree
To solve the fourth-degree equation r^4 + r^3 - 7r^2 - r + 6 = 0, it is noted that r = 1 and r = -1 are roots. The typical approach involves guessing potential roots and using polynomial long division to simplify the equation. The Rational Root Theorem can help identify possible rational roots, which in this case are limited to integers due to the leading coefficient being 1. After factoring out the known roots, the remaining quadratic equation r^2 + r - 6 = 0 can be solved, yielding the additional roots of -3 and 2. The discussion emphasizes the importance of experience in recognizing polynomial behavior and suggests using computational tools for assistance if needed.
nmbr42
From the higher order linear homogeneous differential equation, I get the characteristic equation:
r^4 + r^3 -7r^2 -r + 6 = 0
solve for r.
how do you do this?
Even if I factor out the r from the first 4 terms on the LH, i get no where. I wish in high school they went over this stuff, but they seriously didn't
solve for r.
how do you do this?
It's fairly easy to see that r = 1 is a solution.
Almost as easy to see that r = -1 is also a solution.
nmbr42: the usual approach is to guess, using your experience of how the equations work, then use long division to remove the guessed factors. It is usually taught in junior High School. Possibly you were sick that day or more interested in other things.
How easy it is to realize that 1 and -1 are roots does kinda depend on your experience with these things... but you do learn how to make good guesses as you become familiar with the way polynomials behave.
In a pinch you can use Newton/Raphson to get the first root, or just use a computer to plot the graph :) and there are general solutions online.
One important guide to making "guesses" is the "rational root theorem".
"Any rational number, satisfying a_nx^n+ a_{n-1}x^{n-1}+ \cdot\cdot\cdot+ a_1x+ a_0= 0, is of the form m/n where m evenly divides the "constant term", a_0 and n evenly divides the "leading coefficient", a_n."
Of course, it is always possible that a polynomial equation does not have any rational roots but we can tell that if this equation has rational roots, they must be integers (because the leading coefficent is 1 and only 1 divides 1) and must be 1, -1, 2, -2, 3, -3, 6, or -6 (because the constant term is 6 and only those numbers divide 6).
I actually used this link to help me since Simon Bridge mentioned about long division:
http://www.purplemath.com/modules/polydiv3.htm
quite simple straight forward method.
the roots are -3,2,1, and -1.
Since -1 and 1 are guesses that actually worked, I first divided the equation by (r-1) then (r+1). Then at last you get the equation
r^2 + r -6 =0
no worries... it's all good and glad we could help :)
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
