Solving a Logic Problem: Prove ~(A * F)
  • Thread starter Thread starter particlepat
    Logic
The discussion revolves around solving a logic problem where the goal is to prove ~(A * F) given the premises ~(A * G), ~(A * E), and G v E. The user attempts to apply DeMorgan's theorem to simplify the negated conjunctions, resulting in ~A v ~G and ~A v ~E. However, they express confusion about how to proceed from these simplifications to reach the desired conclusion. The conversation highlights the importance of understanding logical rules and the application of DeMorgan's theorem in this context. Ultimately, the user seeks guidance on proving that A is false using the provided rules.
particlepat
Hey everyone I'm new to the forums and I came here because I completely stumped. This is basic logic but for some reason I'm having trouble with this one.
1) ~(A * G)
2) ~(A * E)
3) G v E / prove ~(A * F)
As I go through and show each step I have to give which rule is being applied.
Rules I can use
Modus Ponens MP
Modus Tollens MT
Disjuctive Syllogism DS
Simplification Simp
Hypothetical Syllogism HS
Constructive Dilemma CD
Conjunction Conj
Addition Add
DeMorgan DM
Associativity Assoc
and Distribution Dist
Rules I can't use
Transposition
Implication
Exportation
Tautology
The first time I proved it but after reading the instructions I realized I'm not supposed to use tautology or material implications. It may be as simple as not knowing exactly how to simplify something like ~(A * G) when it's when the whole equation is negated.
Any help would be great.
I'm not really an expert on all of this logic terminology, but isn't simplifying ~(A * G) DeMorgan?
right so assuming I did the following:
1) ~(A * G)
2) ~(A * E)
3) G v E /need to prove ~(A * F)
4) ~A v ~G because DM on line 1
5) ~A v ~E because DM on line 2
This is about where I get stuck...
1) ~(A * G)
2) ~(A * E)
Like I said, I don't know logic formalism very well. But it's pretty clear you want to prove A is false. Can you do that using one of those rules?
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
