Solving a Matrix with variables
  • Thread starter Thread starter brownman
    Matrix Variables
The discussion revolves around solving the equation involving a matrix product set to zero, specifically focusing on finding values of k. The user initially struggles with whether the matrix is homogeneous and the implications for the solutions of k. After multiplying the matrices, they derive a quadratic equation, but encounter issues with their calculations and results. Clarifications are provided regarding notation and the correct formulation of the equation, leading to the conclusion that the problem has been resolved with assistance from the instructor regarding the homework system. The user expresses gratitude for the help received.
brownman
Find all values of k, if any, that satisfy the equation.
[2 2 k]*[1 3 0; 3 0 5; 0 5 -1][2 ; 2 ; k]=0
Multiplying the two matrices on the right
[2 2 k] * [8 ; 6 +5k ; 10-k]=0
Multiply again
[ 16 + 10+12k + 10k-k^2]=0
I'm stuck here, because I'm really confused about whether this is a homogeneous matrix or not, or if there are infinite solutions to k because the variable just needs to be zero.
Thanks for any help :)
Multiply again
I'm not sure I understand your notation, but it looks for the matrix product to be zero, you need 16 + 10+12k + 10k-k^2 = 0. That's a quadratic equation, so should be easy to solve for k.
I've left it in MATLAB notation, so the semi colons indicate a new row and spaces mean the next entry is in the next column.
Thanks for helping me clear that up, I used the quadratic equation to solve for k but I got the roots 10±8\sqrt{2} which are apparently incorrect. Perhaps it's at this point an error with my online homework system. Oh well.
You transposed a couple of numbers. It should be 16 + 12 + 10k + 10k - k^2 = 0
This part is irrelevant - the exercise is to find values of k for which the matrix product is 0.
I believe I made a typo here in entering, as I still return 10\pm8\sqrt{2} as the roots. The problem has been solved though, my instructor sent an email regarding the error with the homework system.
Again, thank you for your help!
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
