Solving a second order differential equation using Laplace transforms
7 replies · 3K views · last reply
Bibbster
Hey guys , having a bit of bother getting a solution for this question. Any help would be greatly appreciated!
There is a Picture attached showing how far I have got ..View attachment 1586
Re: Second order differential help (laplace)
How I would do is solve the homogeneous which is relatively trivial and you get
y_c = e^{-\frac{1}{2}t}\left[c_1\cos\left(t\frac{\sqrt{15}} {2}\right) + c_2\sin\left(t\frac{\sqrt{15}} {2}\right)\right]
Then let \(y_p = at^2 + bt + c + d\cos(2t) + e\sin(2t)\).
Then take \(y_p'' + y_p' + 4y_p = \text{RHS}\), equate the coefficients, and then use linear alg to find the coefficients of the paticular solution.
I just saw you wanted a Laplace transform.
When I apply \(\mathcal{L}\), I get
s^2y(s) - s - 2 + sy(s) - 1 + 4y(s) = \frac{8}{s^3} + \frac{2}{s^2} + \frac{2}{s} + \frac{s}{s^2 + 4} + \frac{2}{s^2 + 4}
which simplifies to
(s^2 + s + 4)y(s) - s - 3 = \text{RHS}.
I don't think we have the same here.
y_c = e^{-\frac{1}{2}t}(c_1\cos(t\sqrt{15}) + c_2\sin(t\sqrt{15}))
Then let \(y_p = at^2 + bt + c + d\cos(2t) + e\cos(2t)\).
Just letting you know that you made a minor mistake in your $y_p$; you accidentally put $\cos(2t)$ twice (i.e. $d\cos(2t)+e\cos(2t)$ when I'm sure you meant $d\cos(2t)+e\sin(2t)$.
which simplifies to
I see where the confusion is coming from , my mistake v(o)=-1 rather than 1 as it says in above picture. Sorry about that! However, was I along the right lines in my above working or?
which simplifies to
I apologize for being a nuisance, had a look at this when i got home from work again and noticed the following:
[tex]\displaystyle \dfrac{2s}{(s^2+4)(s^2+s+4)} \ = \ \dfrac{2s}{(s^2+4)} + \dfrac{2s}{(s^2+s+4)}[/tex]
is incorrect ^^^ as i had in initial workings.
Following on from this i had an idea that if i split up the first term i could get: [tex]\displaystyle \ \dfrac{-s}{(s^2+s+4)} + \dfrac{1}{(s^2+s+4)}[/tex] which would then leave me to find possible solutions for [tex]\displaystyle (s^2+s+4)[/tex] with one being [tex]\displaystyle =(s+0.5)^2+15/4[/tex]. Then after that (if correct) I'm once again confused . :(
below are my new workings to keep you guys on track with what I am thinking. (first term isn't split up as unsure ).
That fraction you are speaking of reduces to
\frac{2}{s^2+4}-\frac{2}{s^2+s+4}
as you said , i now have [tex]\dfrac{2}{(s^2+4)}[/tex][tex]-[/tex][tex]\dfrac{2}{(s^2+s+4)}[/tex] with [tex]\dfrac{2}{(s^2+4)}[/tex] becoming [tex]Sin2t[/tex] and [tex]\dfrac{2}{(s^2+s+4)}[/tex] becoming [tex]\dfrac{2}{(s^2+0.5)^2+15/4}[/tex] however I am struggling to tackle this one , if you could point me in right direction that'd be great
Now recall that $\mathcal{L}^{-1}\{F(s-a)\} = e^{at}f(t)$
Hence,
\[\mathcal{L}^{-1}\left\{\frac{2}{\left(s +\frac{1}{2}\right)^2 +\frac{15}{4}}\right\}= e^{-\frac{1}{2}t}\mathcal{L}^{-1}\left\{\frac{2}{s^2+\frac{15}{4}}\right\}\]
Can you take things from here?
