Solving an Initial value problem using Laplace transform
13 replies · 3K views
Rubik
Solve the Initial value problem using Laplace transform
[itex]\ddot{y}[/itex] +2y = 0, y0 = C1, [itex]\dot{y}[/itex] = C2
[s2 - sy(0) - y'(0)] + a[sY - y(0)] + bY
s2Y - sy(0) - y'(0) + 2y = 0
s2Y + 2Y = sy(0) + y'(0)
(s2 + 2)Y = s(C1) + (C2)
Y = (s(C1))/[s2 + 2] + (C2)/[s2 + 2]
And that is as far as I can get as I am unsure what to do now?
Well the laplace transform of what function gives the form s/(s2+k2)?
Similarly what function's transform give k/(s2+k2)?
(Hint:Think trig functions)
Oh so I use cos[itex]\omega[/itex]t
Actually I am confused does that mean for the first bit my answer is cos([itex]\sqrt{2}[/itex] t) what happens to the C1?
Right so cosωt would give ω/(s22), so comparing this to C1* s/(s2+2) what is ω ?
The C1 should be there, even if your book says it isn't there, it should be there still.
so is my answer just C1cos([itex]\sqrt{2}[/itex] t) otherwise I am really confused..
My book says it is s/(s2 + [itex]\omega[/itex]2) and not a numerator of [itex]\omega[/itex]
No, remember you have two functions.
Sorry, I wrote the other one.
s/(s22) compared to s/(s2+2) gives ω as?
If you are confused as to what I am trying to get you to see, look up the laplace transforms for cosine and sine.
so [itex]\omega[/itex]2 = 2 which implies [itex]\omega[/itex] = [itex]\sqrt{2}[/itex]?
Good. So you have [tex]Y(s) = C_1 \frac{s}{s^2+\omega^2} + (C_2/\omega)\frac{\omega}{s^2+\omega^2}[/tex]where [itex]\omega^2 = 2[/itex]. Note I multiplied and divided the second term by ω to get the Laplace transform to look like one in the table. The first term corresponds to [itex]C_1 \cos \omega t[/itex], as you noted earlier. What do you get for the second term?
Is it right to do the second term as C2(1/(s2 + 2) which corresponds to (1/[itex]\sqrt{2}[/itex]) sin([itex]\sqrt{2}[/itex]t)?
Thank you so much for all your help :D I am finally beginning to understand!
Just use tables! Of course you have to jiggle your constants around a bit in order to accommodate the particular form your tables happen to be in.
