Engineering Solving an RC circuit question using Superposition
The discussion revolves around analyzing an RC circuit using superposition after a switch is opened at t=0. The initial nodal analysis yields a current of 66.67 - 16.666 e^{-t/120} micro Amps across R11, attributed to an 8V source and a capacitor. A key question arises regarding whether the currents from both sources should be added, as they flow in the same direction towards R11. Participants clarify that while the capacitor's current is indeed positive, the book's approach of subtracting it from the 8V source's current is correct due to the changing nature of the capacitor's influence over time. Ultimately, understanding the capacitor's behavior as a variable voltage source is crucial for accurate analysis.
ecy5maa
Hello,
The circuit attached below is from Richard Dorfs Intro to Electric Circuits book. The switch is shut for a long time and opened at t=0.
The question asks to find the i(t) across R11, which they use nodal analaysis and find it to be 66.67 - 16.666 e^{-t/120} micro Amps, where 66.67 micro Amps is due to the 8 v source and - 16.666 e^{-t/120} source due to the capacitorMy question is that if we use superposition instead, should the current due to the 8 v source and the capacitor be added since both send current towards R11 in the same direction?Thank you in advanceP.S since this is more a theoretical question, i thought best i post it here other than the Homework section
ecy5maa said:
Hello,
First, I think when the switch open, Cap is not going to send current to R11 in the same direction as the 8V battery. Because if you use super position to find the voltage at probe11 when the switch is closed, the voltage is lower than when the switch is open for a long time. The final voltage at this point will be 4V after the switch opened for a long time and let everything settle.
I have not think in detail how to do the calculation, but super position definitely will work. My guess is to treat the cap as a variable voltage source that slowly rise from initial voltage, with the time constant of RC where R = R10 and R11 in parallel and you have to calculate the thev. voltage or something like that to the final voltage of 4V. As I said, I am too lazy to go into the detail, but the answer is yes, you have to include the cap. until the circuit settle.
Yungman
I made a mistake above. The current due to the capacitor is 16.666 eLaTeX Code: ^{-t/120} not - 16.666 eLaTeX Code: ^{-t/120}.
However in the book instead of adding the current...they are subtracting them. This is what i don't get since both currents ( current due to the 8V voltage source and current due to the capacitor) are in the same direction
So shouldn't it be added and hence shouldn't the answer be 66.67 + 16.666 eLaTeX Code: ^{-t/120} and not 66.67 - 16.666 eLaTeX Code: ^{-t/120}
Any help in this regard will be helpful...Also i don't have the book with me but the answer is correct.
  • · Replies 46 ·
11K
