Engineering Solving Circuit Analysis Problem: Find V - Power of 5Ω Resistor is 20W
The problem involves finding the total voltage supplied to a circuit with a 5Ω resistor absorbing 20W of power. The voltage across the 5Ω resistor is calculated to be 10V, leading to a current of 2A through it. The circuit also includes 2Ω and 3Ω resistors in series, which combine to 5Ω, maintaining the same current of 2A. The total current flowing through the circuit is determined to be 4A. Ultimately, the total voltage supplied is found to be 18V.
hackett5
Hello, I was hoping someone could walk me through the steps to solve this problem:
The power absorbed by the 5Ω resistor is 20W. Find V
http://img191.imageshack.us/img191/6411/14966985.jpg
V= I x R
P = V2/R
I first found the voltage across the 5Ω resistor to be 10V using V= I x R and substituting 20W / V for the current. How do I find the total voltage supplied?
You know the voltage across the resistor, good. So you know the voltage of the node above the 5Ohm resistor. Can you tell us how much current goes in and out of that node? Where does it come from? Where does it flow to?
Well, using I= V/R, I get 2A (I1) going through the 5Ω node. The 2Ω and 3Ω resistors are in series so I can combine them as 5Ω. So through that node the current would also be 2A (I2) and voltage would be 10V. Then I2 + I1= Itotal or 2A +2A= 4A? The total resistance would be 2.5Ω and voltage = 10V?
So the total voltage would be: V= 10V + the voltage across the 2Ω resistor.
V= 10V + (2Ω x 4A)
V=18V
Bingo!
Awesome! Thanks for the help
12K
