Solving Complex Velocity from Particle Falling in Gravity
4 replies · 2K views · last reply
fobos3
I'm trying to derive the equations of motion for a particle falling in a uniform gravitational fill with air drag proportional to the square of velocity. However I'm getting the velocity as a complex number. Here is what I've done
The force of friction is [tex]F=-k\left(\dfrac{dx}{dt}\right)^2\dfrac{\textbf{v}}{||\textbf{v}||}=-k\left(\dfrac{dx}{dt}\right)^2[/tex]
We put the particle stationary at [tex]x=0[/tex]
The Lagrangian is [tex]\mathcal{L}=\dfrac{1}{2}m\left(\dfrac{dx}{dt}\right)^2-mgx[/tex]
[tex]\dfrac{d}{dt}\left(\dfrac{\partial \mathcal{L}}{\partial \dot{x}}\right)-\dfrac{\partial \mathcal{L}}{\partial x}=-k\left(\dfrac{dx}{dt}\right)^2[/tex]
[tex]m\dfrac{d^2 x}{dt^2}+mg=-k\left(\dfrac{dx}{dt}\right)^2[/tex]
If we put [tex]c=\dfrac{k}{m}[/tex]
[tex]\dfrac{d^2x}{dt^2}+c\left(\dfrac{dx}{dt}\right)^2+g=0[/tex]
We put [tex]p=\dfrac{dx}{dt}[/tex]
We have [tex]\dfrac{d^2x}{dt^2}=\dfrac{dp}{dt}=\dfrac{dp}{dx}\dfrac{dx}{dt}=\dfrac{dp}{dx}p[/tex]
The differential equation becomes
[tex]\dfrac{dp}{dx}p+cp^2+g=0[/tex]
[tex]\dfrac{p}{cp^2+g}\dfrac{dp}{dx}=-1[/tex]
[tex]\int\dfrac{p}{cp^2+g}\,dp=-x[/tex]
To solve the integral we put [tex]u=cp^2+g[/tex]
[tex]\dfrac{du}{dp}=2cp[/tex]
[tex]p=\dfrac{1}{2c}\dfrac{du}{dp}[/tex]
[tex]\dfrac{1}{2c}\int \dfrac{1}{u}\,du=-x[/tex]
[tex]\int \dfrac{1}{u}\,du=\ln |u|=\ln u[/tex] because [tex]u>0[/tex]
[tex]\dfrac{1}{2c}\ln (cp^2+g)+A=-x[/tex]
[tex]A(cp^2+g)=e^{-2cx}[/tex]
At [tex]t=0,x=0,p=0[/tex]
[tex]Ag=1[/tex]
[tex]A=\dfrac{1}{g}[/tex]
[tex]\dfrac{c}{g}p^2+1=e^{-2cx}[/tex]
[tex]p^2=\dfrac{g(e^{-2cx}-1)}{c}[/tex]
Now the sign of [tex]\dfrac{g(e^{-2cx}-1)}{c}[/tex] is determined by [tex]e^{-2cx}-1[/tex] which is not necessary positive definite.
In fact if we put [tex]c=1,x=1[/tex] we get [tex]e^{-2}-1<0[/tex] which means that [tex]p\in \mathbb{C}[/tex]
But [tex]p=\dfrac{dx}{dt}[/tex] which makes no sense at all. Did I do something wrong?
The sign of the drag force in the above equation is wrong.
By the way, I don't see why we have to use Lagrangian here, since Newtonian method is much more simple.
EDIT: Actually you may change either the sign of the drag force or the sign of the potential energy, but only one of them. Both yield the same correct equation.
I think you have a sign issue here. Shouldn't it be:
[tex]m\dfrac{d^2 x}{dt^2}=mg-k\left(\dfrac{dx}{dt}\right)^2[/tex]
Mass*acceleration equals the sum of the forces. The net force is gravity minus drag.
Yes I see that now. Can you explain where I went wrong in my derivation of the friction.This is what I thought
[tex]F=-k\dot{x}^2 \hat{\textbf{v}}[/tex]
[tex]\hat{\textbf{v}}=\dfrac{\textbf{v}}{||\textbf{v}||}=\dfrac{(\dot{x})}{\dot{x}}=(1)[/tex]
Where the brackets denote a vector in the x direction.
Now obviously [tex]\hat{\textbf{v}}=(1)[/tex] is wrong, because the particle accelerates in the negative direction, but why?
Edit
Never mind. I find out on my own.
There is nothing wrong with [tex]\vec{F}=-kv^2\hat{v}[/tex]. But you must be careful when jotting down [tex]F = -kv^2[/tex] (*) (that means F<0). Since the ball is falling, the force must act upwards. So when you write (*), that means the positive direction of x-axis is downward.
Now in order that potential energy V = mgx, the x-axis must point upwards, which is inconsistent with (*) as explained above.
