Solving Delta-to-Wye Circuit: Find Current Across Inductor
  • Thread starter Thread starter MohdAziz
    Delta Method
The discussion revolves around solving a circuit problem involving finding the current across an inductor in a Delta circuit using the Delta-to-Wye transformation method. Participants explore various approaches, including voltage divider rules and node voltage calculations, while addressing challenges related to complex impedances and circuit analysis techniques.
  • Homework-related
  • One participant describes their approach using the Delta-to-Wye transformation and shares their calculated total impedance and phasor current.
  • Another participant suggests calculating node voltages at points A and B after the transformation to find the current across the inductor.
  • There is a discussion about applying the voltage divider rule with complex impedances, with some participants questioning how to handle sinusoidal voltage sources.
  • Concerns are raised about the voltage at node A being higher than expected, prompting discussions on potential calculation errors and the implications of impedance calculations on voltage results.
  • Participants share their work and seek feedback, indicating a collaborative effort to refine their understanding and calculations.
  • One participant acknowledges a mistake in their impedance calculation but believes it does not affect the overall voltage calculations.
  • Another participant points out that errors in impedance calculations can impact the results for other voltages and currents in the circuit.
  • Final calculations are discussed, with one participant correcting their treatment of the inductor's impedance and arriving at a new phasor form for the current.
Participants express various approaches to solving the problem, with some agreeing on the use of the Delta-to-Wye transformation while others suggest alternative methods like node analysis. There is no consensus on a single method or solution, as participants continue to explore different aspects of the problem.
Participants mention specific impedance values and calculations, but there are uncertainties regarding the accuracy of these values and their impact on the overall analysis. Some calculations are noted to be dependent on earlier results, which may introduce further complications.
Students and practitioners interested in circuit analysis, particularly those studying Delta-to-Wye transformations and complex impedance calculations in electrical engineering contexts.
MohdAziz
Hello, I have this question that I've been working on. The question requires me to find the current across an inductor in a Delta circuit, so I want to solve this question using Delta-to-Wye method. so I transformed it using the method and I found the total impedance of the whole circuit, then I divided the phasor voltage by the impedance and I found the current, but I still have no idea how I can find the current across the inductor. I attached a picture of the question so you guys can see my problem.
The result of the total impedance was around ( 82 - 64.07i)
and the phasor current after dividing by the phasor voltage is 0.6731 < 38
Thanks a lot, your help is really appreciated.
Say that you transform R1 R2 and ZL1 from delta to star. As you've found, you now have a series - parallel circuit that is amenable to "ladder style" collapsing. You do lose track of L1 in the process (it gets tangled up with R1 and R2 in the transform), more importantly however you do still have access to nodes A and B.
So you can calculate the voltages at A and B from the transformed circuit, then using this knowledge of [itex]V_{AB}[/itex] you can then go back to the original circuit to solve for Ix
Okay. I got your idea, by that Va should the voltage across the capacitor and Vb should the voltage across R3 but the thing how could I find the voltage or apply the voltage divider rule in case of a sinosoidal voltage source.
just to tell you
Z1= 16 - 21.33i
Z2= 51.2 + 38.4i
Z3 = 64 - 48i
when I apply the voltage divider rule to Z1, VZ1 = Vin * Z1/ Ztot
all of Z1, Z total and Vin should be in phasor form?
Thanks a lot man.
Yeah that's right. Just use complex numbers for all the impedances and use the voltage divider rule with complex numbers. For the source voltage use 70 + j0 (70 angle 0).
If you apply a Δ-Y transform to the circuit you will "transform away" the component through which you want to find the current (L1). However, nodes A and B still exist in the "new" layout, so you could calculate their node voltages. With the two node voltages in hand you can go back to the original layout to determine the potential difference across L1 and hence its current...
A more straightforward approach might be to write KVL mesh or KCL node equations for the original circuit.
Okay that's great, I think I got the picture. I'll solve the whole thing and I'll scan and attach it to show it to you so I can know your remarks, of course if you don't mind?
Okay. The thing I'm supposed to do it using delta to wye, however; If I ever have time, I'll try the node analysis. And if you don't mind, can I solve the whole thing, and attach it so I can show and you could tell me what are my mistake, if I have any?
And thanks a lot for your help;.
Yes, you are encouraged to show your work :smile:
There is this one weird thing that I came across when solving the question, as you know to find the voltage of node A, you have to find the voltage of the capacitor, therefore; firsr you need to find the voltage of the whole parallel part by applying voltage divider rule like this (Zparallel/ Zparallel + Z1)* 70<0 ... The answer would be 52.92<5.076. Then you use this in voltage divider rule again to find the capacitor voltage Like this, (Xc/Xc + Z2)* 52.92<076. However the weird thing that the voltage of node A (capacitor) is actually higher than the voltage of whole parallel part, and this should be impossible. I tried to check all of my results, but I'm quite sure I haven't made any calculation mistakes?
Here you go, this is my work. BTW I tried also to find the current through the capacitor and then find the voltage but I got a different result as well :S
You'll want to recheck your calculation for Z3. Otherwise, your method of work looks fine.
You're right Z3 here is wrong, but when I calculated the total Z I used the right calculation which is 64 + 48i , and the answer of the Z of Parallel would still be 66 - 42.74. And thus the total Z is 82 - 64.07. And when we calculate Va we just need the Z parallel and Z tot so the mistake in calculation Z3 won't have any effect on the result of Va.
It does, however, impact Vb which in turn effects Va-Vb for the calculation of Ix.
Anyway I was concerned bcuz when we find the magnitude of Va in polar form it's greater than the magnitude of the parallel voltage in polar form. However; I decided to check the total voltage of Vz2 + Va in rectangular form and it was equal to the parallel voltage which I guess my answer is correct. Anyway I resolved everything and I corrected my mistakes and here is my final work.
Thanks a lot for your help, could you please check it for the last time. I really appreciate your help.
It all looks fine except for your final calculation of Ix; the impedance of the inductor should be an imaginary value (240j Ω), but it seems that you've treated it as a real value.
oh missed that. SO final answer should be (28.93 - 22.27j)/240j = -0.093 +0.120i which equals to 0.152 < -127.59 in phasor form. Thanks a lot gneil, and sorry for that coin in my last solution sheet :D
Yes, that looks better :approve:
Next time post a cheque; paper coins are hard to cash :smile:
Hahaha, you got it :biggrin: take care
  • · Replies 62 ·
  • · Replies 18 ·
