Solving differential equation from variational principle
JulieK
I have the following differential equation which I obtained from Euler-Lagrange
\frac{\partial}{\partial x}\left(\frac{1}{\sqrt{y}}\frac{dy}{dx}\right)=0
I also have two boundary conditions: y\left(0\right)=y_{1} and
y\left(D\right)=y_{2} where D, y_{1} and y_{2} are known
numbers.
I assume that I should integrate once to get
\frac{1}{\sqrt{y}}\frac{dy}{dx}=f\left(y\right)
where f\left(y\right) is a function of y. I would like to get
y as a function of x but the problem is that I don't know the
form of f\left(y\right).
My question, how to solve this equation to get y as a function
of x. Is it possible to guess the form of f\left(y\right), e.g.
from the bounday conditions.
JulieK,
I am not sure I understand: why are you applying a partial differential operator to what looks like a function of one variable? If that is just a typo, then your equation gets much easier: you just equate the term inside the parenthesis to a constant and get an ODE that is integrable by part.
Thread 'Direction Fields and Isoclines'
I sketched the isoclines for $$ m=-1,0,1,2 $$. Since both $$ \frac{dy}{dx} $$ and $$ D_{y} \frac{dy}{dx} $$ are continuous on the square region R defined by $$ -4\leq x \leq 4, -4 \leq y \leq 4 $$ the existence and uniqueness theorem guarantees that if we pick a point in the interior that lies on an isocline there will be a unique differentiable function (solution) passing through that point. I understand that a solution exists but I unsure how to actually sketch it. For example, consider a...
