Solving Enthaply by other ways?
  • Thread starter Thread starter fubear
The discussion revolves around the adiabatic expansion of 2 moles of an ideal gas, questioning the calculations of work (w), change in internal energy (dE), change in enthalpy (dH), and temperature change (dT). Initial calculations show w and dE as -997.78J, while dH is derived using different methods, yielding inconsistent results, leading to confusion about the correct approach. There is a debate on whether dH can be calculated using the formula dH = dE + d(PV) and the implications of constant pressure on dH and heat transfer (q). Participants clarify that while the external pressure remains constant, the process is adiabatic, affecting temperature and internal energy. The conversation highlights the complexities of thermodynamic calculations and the importance of understanding process definitions.
fubear
2 moles of an ideal gas at 300K and 5 bar is expanded adiabatically at a constant pressure of 1 bar till the volume doubles. Cv = 3R/2. Calculate w, q, dE, dH and change in T.
I found that w = dE = -997.78J
In class we solved dH by:
dH = CpdT = -1.66kJ
(we found Cp by Cp=Cv+nR ; we found dT by Cv=dE/dT)
I was wondering if we could solve dH another way:
dH = dE + d(PV)
However, I get a different answer..
dH = dE + Pext dV (because pressure is constant)
dH = -997.78J +-997.78J (because Pext dV is work)
dH = -2.00 kJ
I also tried another way:
dH = dE + d(nRT)
dH = -977J + (2mol)(8.3145J/K)(-80K)
dH = -1.08kJ
I am not getting the same value for each of the different ways I am using... Am I doing something wrong or am I not allowed to solve dH using the other methods?
Also, at constant pressure, isn't dH = qrev.. and q=0, so shouldn't dH = 0?
Thank you
It is adiabatic or at constant pressure? How can be both?
The external pressure is constant, but the system undergoes an adiabatic process
I'm with nasu here. If the gas expands adiabatically pushing out a piston, then it will do work pushing out the piston, and its internal energy will fall. So, therefore, will its temperature, and its pressure (since P = nRT/V and T goes down and V goes up).
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
