Solving for Line Currents in a Wye-Delta Circuit
1 reply · 12K views · last reply
scothoward
Hi,
In the attached file, the question asks to find the three line currents. I understand the solution using Mesh Analysis that was used. However, I am unsure as to why when I convert the Delta Load to a Wye load, I get the wrong answer.
Using Zwye = (1/3)Zdelta, adding the series line impedance with the load impedance, and then finding the line current using a single phase equivalent.
Essentially the Balanced Delta load becomes a Balance Wye load of 4 + j0.666. Then the line impedances will be in series with each individual load. So each impedance should be (4 + j0.666) + (1 + j2). Finally, the line currents will be the phase voltages (100 angle0, 100 angle-120, 100 angle120) divided by the series line and load impedance, 5 + j2.666.
Am I doing something wrong?
  • Circuit schematic of a three-phase wye-delta network with mesh currents I1, I2 and I3, impedances 1 + j2 ohms in the lines, 12 + j12 ohms in the delta load, and source phasors 100 angle 0 and 100 angle 120 volts, with mesh equations and solutions below.
I can't help you here, because there is no question to what need to be solve.
