Solving for Minimum Duct Diameter in a Hospital Room Air Exchange System
  • Thread starter Thread starter Naeem
    Thermo
To determine the minimum duct diameter for a hospital room air exchange system, first calculate the room's volume, which is 120 cubic meters. The air must be replaced every 20 minutes, leading to a required volumetric flow rate of 6 cubic meters per minute. With a maximum air velocity of 5 m/s, the duct's cross-sectional area can be derived from the flow rate. Using the relationship between flow rate, area, and velocity, the minimum diameter of the duct can be calculated. This approach ensures efficient air exchange while adhering to the specified velocity limit.
Naeem
Q. The air in a 6m x 5m x 4m hospital room is to be completed replaced by conditioned air every 20 min. If the average air velocity in the circular air duct leading to the room is not to exceed 5 m/s, determine the minimum diameter of the duct.
We can figure out the volume of the room, knowing the dimensions then what.
time is given, what else can be done?
think about volume flow rate...
Ok, found out volume flow rate what next
- You have the volume of the room that needs to be replaced every 20 minutes. That should tell you something about the volumetric flow rate needed to come out of the duct.
- If you have a flow rate, what equation also contains the duct's cross sectional area and it's velocity?
Those are two pretty big hints there.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
