Solving Normalization with Psi(r)=Ne^(-ar)
The discussion focuses on solving the normalization integral for the wavefunction psi(r) = Ne^(-ar), where N is a normalization constant and a is a known real parameter. The integral is evaluated as 1 = ∫ dr |psi(r)|^2 = 4πN² ∫ (from 0 to infinity) dr r² e^(-2ar). The key to understanding the limits of integration from 0 to infinity lies in the use of spherical coordinates, where the volume element is expressed as dV = (r sin(θ))(r dφ) dr, leading to a triple integral for normalization.
  • Understanding of wavefunctions in quantum mechanics
  • Familiarity with spherical coordinates and volume integrals
  • Knowledge of normalization conditions in quantum mechanics
  • Basic calculus, particularly integration techniques
  • Study the derivation of normalization integrals in quantum mechanics
  • Learn about spherical coordinates and their applications in physics
  • Explore the properties of exponential functions in integrals
  • Review the concept of factorial in relation to gamma functions
Students and professionals in physics, particularly those focusing on quantum mechanics, as well as mathematicians interested in integral calculus and normalization techniques.
precondition
Hi there
I'm stuck on one of the normalization question,
I'd be glad if you can help me out.
The questions is, psi(r)=Ne^(-ar) where N is a normalization constant and a is a known real parameter.
Solution reads, 1=int dr lpsi(r)l^2 = 4piN^2 int (from 0 to infinity) dr r^2 e^(-2ar)
What I don't get is how to get integral from 0 to infinity?(instead of -infinity to +infinity) with extra factor 4pi r^2?
Thanks for your help
P.S. the solution also says, use the following integral, n larger than or equal to 0: int(0 to infinity)dx x^n e^(-x)=n factorial
I don't get where you use above integral.
It seems you are stuck with math problem. Here is a little help:
In order to calculate normalization, you need to calculate volume integral from equation:
\int_{all space} |\Psi(\vec{r})|^2 d \vec{r} = 1.
Now the thing is, people use notation d\vec{r} to actually mean a little volume element (dV if you will). In spherical coordinates, small element of space (volume) can be written as:
dV = (r \sin{\theta}) (r d\phi) dr,
where r now represents distance from the origin (the length of vector r). To cover all space when using spherical coordinates, you need to take the limits for three variables (r from 0 to infinity, theta from 0 to pi, phi from zero to 2pi; these can be easily visualized if you draw a picture). Therefore, normalization integral is actually triple integral:
\int_{r=0}^{\infty} \int_{\theta = 0}^{\pi} \int_{\phi = 0}^{2\pi} |\Psi(r, \theta, \phi)|^2 r^2 \sin{\theta} d\phi d\theta dr.
If wavefunction depends only on variable r (\Psi(\vec{r}) = \Psi(r, \theta, \phi) = \Psi(r)), you can actually carry out integration over theta and phi. Try to do yourself from here :smile:
  • · Replies 22 ·
  • · Replies 21 ·
