Solving a PDE with Non-homogenous Boundary Conditions
In summary, a PDE, or partial differential equation, is a type of mathematical equation used to model physical phenomena. Non-homogeneous boundary conditions are conditions that must be satisfied at the boundaries of a system, where the solution to a PDE is being sought. To solve a PDE with non-homogenous boundary conditions, the PDE must be classified and the boundary conditions incorporated into the solution method. The difference between a homogeneous and non-homogeneous PDE affects the solution method and the nature of the solutions. Non-homogeneous boundary conditions are important because they allow for a more accurate representation of real-world systems and phenomena.
kgal
43
If utt - uxx= 1-x for 0<x<1, t>0
u(x,0) = x2(1-x) for 0≤x≤1
ut(x,)=0 for 0≤x≤1
ux(x,)=0
u(1,t)=0
find u(1/4,2)
I was thinking to make a judicious change of variables that not only converts the PDE to a homogenous PDE, but also makes the boundary conditions homogenous.
I am quite unsure how to even start this problem...
Consider that the solution has the form: u(x,t)=v(x,t)+w(x). Can you find the boundary and initial conditions to make this problem simpler?
Related to Solving a PDE with Non-homogenous Boundary Conditions
What is a PDE?
A PDE, or partial differential equation, is a type of mathematical equation that involves multiple independent variables and their partial derivatives. These equations are commonly used to model physical phenomena in fields such as physics, engineering, and economics.
What are non-homogenous boundary conditions?
Non-homogenous boundary conditions are conditions that must be satisfied at the boundaries of a system or region, where the solution to a PDE is being sought. These conditions include values or functions that are not equal to zero, unlike in homogenous boundary conditions where the values or functions are equal to zero.
How do you solve a PDE with non-homogenous boundary conditions?
To solve a PDE with non-homogenous boundary conditions, first, the PDE must be classified as either elliptic, parabolic, or hyperbolic. Different solution methods are used for each type of PDE. Then, the boundary conditions are incorporated into the solution method, and the PDE is solved for the desired solution.
What is the difference between a homogeneous and non-homogeneous PDE?
A homogeneous PDE has all terms in the equation equal to zero, while a non-homogeneous PDE has at least one term that is not equal to zero. This difference affects the solution method used to solve the PDE, as well as the nature of the solutions.
Why are non-homogeneous boundary conditions important?
Non-homogeneous boundary conditions are important because they allow for a more accurate representation of real-world systems and phenomena. In many cases, physical systems have non-zero values or functions at their boundaries, and these conditions must be taken into account in order to obtain meaningful solutions to PDEs that model these systems.
  • Math POTW for University Students
