Solving Quadratic and Trigonometric Equations
The discussion centers on solving two mathematical problems: the inequality 5 > x^2 >= -9 and the equation cos(x+30) - sin(2x) = 0. The first problem reveals that x^2 is always non-negative for real numbers, leading to the conclusion that the valid solutions are those where x^2 is less than 5. The second problem involves trigonometric identities, with a solution derived by equating cos(x+30) to sin(2x). Participants clarify misunderstandings about the nature of real numbers and inequalities, ultimately reaching a consensus on the correct interpretations and solutions.
abc
2 questions ...
1- solve :
5 > x^2 >= -9
: x belongs to R
2- solve :
cos (x+30) - sin (2x) = 0
45 >= x >= 0
thanx
regards
abc
Mathematics news on Phys.org
cos(x+30) = sin(2x) = cos (90-2x)
this means : x+30 = 90-2x and x+30 = -90+2x
Then solve to x and you are done...
marlon
x^2 >= -9 for a real number : this is not possible. You only have 5>x^2>=0. The solution : x < sqrt(5 ) and x>-sqrt(5)
Huh? It's true for any real number x.
hallo Huh?
I meant that x^2 is always bigger or equal to zero, when x is considered to be a real number. This does not apply for complex numbers though...
regards
marlon
marlon: you originally said "x^2 >= -9 for a real number : this is not possible." Muzza's point was that it certainly is possible.
You then noted "I meant that x^2 is always bigger or equal to zero".
Yes: x^2>= 0 which is itself larger than -9. x^2>= -9 for all real numbers x.
If you had said "that's always true" rather than "that's impossible" you would have been right: the solutions to 5>x^2>= -9 is exactly the set of numbers whose square is less than 5.
Thank you HallsofIvy ;)
OK I STAND CORRECTED
regards
marlon
